who says jl audio dont bang :p
subs freeze from being over powered the coils lock up.
Correct. And if it was over powered that is user error and NOT JL's fault.
jl 10w0v3/4: Recommended RMS Amplifier Power 75 - 300 W kendwood kac 8402: 90x4 rms w (btw thats at max gain with perfect 4 ohm load) playing music not even turned up and it just stopped...looked at it and it was frozen...(second jl i ever owned)
apologies i have an edit to make, their amps are great amps. but still, the prices of ANY of their products is a complete turn-off to the point where i wont even use the equipment they put out.
once again agreed but i sure as hell wouldnt turn it down it it was free
max gain.
smells like clipping in here..
That's what I was thinking.
Junior, the gain on an amp is there to match the output voltage from the headunits preouts. The higher the headunit output voltage, the less the gain needs to be turned up to achieve the amps max output.
If you had the gain maxed out on that amp, it was probobly clipping the shit out of that sub and unwound the coil in the gap and ceased the cone. That's just my guess though :pardon:
yeah i agree that they are a good company with some good amps but the coils on jls are just not worth it in my book...
To each his own I guess. The only sub I've heard bad things about are the newer W1's.
Don't really care about the JL argument at all, mostly just HEY LOOK SOMEONE ELSE FROM TUCSON!
lol wow that was unexpected dude
max gain.
one yes i know this ranger but seeing as i dont know my pre out voltage and dont have access to a dd1 i simply set the amp to the rms rating of he sub using ohms law(see below)
two i never said that i had it set at max gain i said that my amp is RATED at 90 w rms but thats is with the gain maxed and a perfect 4 ohm load
when i was younger (first system) i thought like 90% of kids with a thrown together system that the gain was basically like an amount to amplify which in basicality it is just how much to amplify the signal but i havent since then because even though i didnt blow any subs back then i realized it was bad on the subs...right now if my amp wasnt hidden under piles of boxes(in the process of moving) i could go look at it and it would be set right at 3v input sensitivity with my amp markings at 5v 3v 2v 1v .5v and .2v markings which means that the amp (even though its hooked up to a different sub that i dont know the rms handling of but due know that its a 24 ohm sub) is set to the square root of 250rms(desired) times the 4 ohm load of my previous sub which comes out to 31.xx volts ac on the dmm
http://www.youtube.c...e1?feature=mheehttp://www.stevemead...87#entry1993187
JVC KD-R530 head unit
VVME INNO-D1500 sub amp
Kenwood KAC-8402 amplifierPioneer 2-way 6.5 X2 @ 4 ohms
DTI Audio 6.5 X2 @ 4 ohmsbox: 4.24 ft^3 tuned to 61 hertz (port walls fell off and dissapeared :( )
Nice! What part of Tucson are you from?
I'm from up in the Foothills, you?
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
Not too far from you, I'm on the NW side. Right off of Ina rd.
Head unit: Pioneer P880prsFront stage: Alpine Type X 17PRO componentsComponent amp: PPI BK 800.4Subs: Two SSA XCON 12's in 4.5 cubes tuned to 34hzSub amp: PPI BK1300.1Sound Deadening: Second Skin Damplifier Pro, Spectrum, and Sludge
Team SSA
Team Alerion
Tucson is an armpit :)
Sure is!
Team SSA
Team Alerion
9 JL 18w6's, this thing drops as low as you can play it
I got tweeters that can do that.... Lol jk. Shit pounds
98 Isuzu Rodeo
Pioneer Deh-6300ub
SUBS
​​*Upcoming* SSA Xcon 18 4th order
AMP
​Banda 3500
Mids/Highs
Pioneer
EQ
Clarion EQS746
ETC.
Two 1/0 run's
KnuKoncepts 1/0 big 3
Shuriken BT-100 under the hood
Shuriken BT-120 in the back
I like my JL set up :shrug:
2015 Mazda 6
JVF Customz 4.0 Proto 15>Wolfram W4500 @ .5ohm
2 Sundown Neo 6.5 + 2 CT Meso Tweeters (Front) x Kicker KS6.5 (Rear)>JL Audio VX400/4i
NSB-AMG35 (front) / 40ah Lithium Headway (Rear) built by Erni Audio & Electrical
Holy hell.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
