When installing in the trunk lid what do you cover up? Like the gaps and space's right..
<p>Pioneer AVIC 6000 NEX, JBL 660c Components - FI SP415- Arc audio xdi2000.1- Xs Power- 0 gauge, Big 3 Upgrade Dc Power xp270
You cover up as small of an area as possible to make it easier to scrape off when you replace it with real deadener.
wtf is lolcats?
I'd def get a fat hooker if i had to resort to that kinda thing. I feel like they'd be grateful and work harder. Also its more bang for my buck, more real estate for my dollar if you catch my drift. its like the Costco of streetwalkers.
I was hoping for 150 :(.
I was hoping she would let me put it in her butt
peal and seal...... LOL
you are wasting your time with peal and seal, adding it doesnt even really do anything beneficial.
lol..
dont use Peel and seal
Peel and seal is prob not your best bet. I can name at least 3 other deadeners that are not horribly expensive and are much better then peel and seal.
Aside from your product of choice, just cover anything and everything, maybe even multiple layers. (4+ layers if your gonna use peel and seal)
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
Deadener should be put on in places that are very thin and have a hollow sound when you tap it.
Its mainly used to add weight to panels to be effective.
1st Setup(SOLD):2007 GMC YukonPioneer Avic F90bt
Audiocontrol Epicenter2 Audioque SDC2.5 15 subs8.7 cubes at 37hz build DONEAudioque 1200d (Audioque 1200d Sold, similar performance to my ap1500)Diamond Audio Hex 6.5 Mids n TweetsCerwin Vega Exl 400 4 channel Bridged(also have MTX 4004 not being used)1 Run of power Knu Fleks 4 Gauge2 Cheap stock Battery setup2nd Setup (SOLD):2007 GMC YukonPioneer Avic F90bt
Audiocontrol Epicenter2 15 Kicker cvx (maybe two SA 15 in future)7 cubes net tuned at 34hzAlphasonik Old school 1600rms (ap 1500d sold GREAT Budget amp)JBL 6.5 Power Series Components, Infinity Kappa 6.5 3 ways, and 2 Kicker KS Tweets (LOUD)Cerwin vega exl4001 run knu Fleks OFC 0 gaugeBig 3 done1 Odyssey 1500, 1 optima yellow top d31
Epic quote of the day?
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
Thought I'd be cheap and install peel and seal. sounded like a good deal. but after it all fell off my rear deck it was a bigger mess than when I started.
EDIT+++
You would be better off spraying on rubberized under coating. At least it would stick.
PPI dbl din
DC Level 3
1.77cubes net tuned to 33htz.
DC audio 2.0k
yeah dude for now id suggest removing all door panels and cleaning the insides with rubbing alcohol or something to get rid of the grease and grime. Then get some real damp. ie stinger road kill, dynamat, second skin, even the cheapass shit on sonics lol anything but peel and seal. You could also greatstuff your whole car that'd be better
Scion tC SQ Build
iPad mini, lots of fabrication, daily driven
Ford Explorer C Pillar Wall Build
Just a cheap car to destroy with bass :D
just get something that will last, and do it once and be done with it. Go second skin or something of that caliber, it might seem expensive until you never have to do it again and dont end up with asphalt based glue all over the place.
  • Who's Online   0 Members, 0 Anonymous, 1325 Guests (See full list)
