its prolly internally fused.
Uhm...an internal fuse is a fuse that sticks out of the side of your amp. Your AQ2200 does not have that. It needs a fuse within 18" of its power wire.
To the OP your Hifonics amp is the same. It needs a fuse within 18" of it's power wire. Probably a 200 amp.
ummm.... the aq manual says it is internally fused at 200 amps.
Aq2200s don't have internal fusing... might want to go buy a fuse.
i shook this one kids hand and it just folded in mine. long story short i fucked his girlfriendso.. yeah..
You want this to happen to you? Give decent handshakes people.
I was gifted with an innate ability to distribute wholesale ass beatings in a timely and orderly fashion.
Uhm.....no its not. Go look at some USAmps for example, they have internal fusing that requires you to remove part of the casing to access them since no part of the fuse is accessible outside the case. Hence the "internal" part.
Just ditch the cap even if you dont do the big3.
What exactly is so bad bout caps?
It's useless....it discharges almost instantly and then the alt has to charge it again. Rinse and repeat. It's a load on the alt more often than it helps.
And there is NO "internal fuse" on an AQ2200. Fuck the manual!
I had an old stetsom 2k6d amp that was supposed to have an internal fuse. You had to take off the cover to the amp and unbolt it from the bolts that go where the positive terminal block and one transformer block are. It was modified so it didnt have an internal fuse so the amp could take more power and give a crap load of output and handle high voltages too. Internal fuses are more like mini ANL fuses that bolt between the power input of the amp and usually the power supply of the amp. Lots of amps out there dont have them such as my dc 5k and 175.4. Even if there was an internal fuse id still run an external fuse just before the amp to be safe and for any chance that you fail to crank down the screw for the power wire and it comes loose the fuse will pop when the wire shorts out and not cause a fire.
2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
My name is AdamThis is my Civic Build.7" Samsung Tab 2Kenwood KDC-X896Clarion EQS746Sundown X-15DC 3.5k @2ohmHatersGonnaHate's 02 Civic UBLELD Bypass for Honda Civic/Accord/FitDon's Jeep Grand Cherokee Rebuild
N8ball2013 - i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol
srp365 - If posting were picking up bitches, I'd be going home single tonight
looks like tony montana sneezed in your car.
good post. Off topic but thats neat how they didnt put the phase adjustment in there but it is ready on the PCB.
