i dont understand why anyone would wanna run their system under 1 ohm. A fried amp isnt worth the extra 2dB if you ask me.
im willing to bet you probably wont see 2db out of it anyways.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
i have a buddy running his at a quarter ohm daily, seeing about a half an ohm rise, so his amp is seeing .75ohms, and it's still doing fine. it doesnt even drop below like 13 volts, if you know what you're doing, it can be done. and those are strong amps.
2x sundown audio sa 12's
Crescendo BC2000
kinetik 1800, 1400.
Rockford punch 5,25 component set
MB QUART ONYX 4.80
Mechman 270a alt
I think it's silly to drop below what the manufacture recomends if it's a daily setup. If you need/want more power, then buy another amp. Cause eventually the amp running below rated WILL fail and you will need to buy another one anyway :pardon:
plus i have never had it heat up. after a few min of play time still feels cool temp
Blowthrough
Subs
rebuild
Amps
1-SAZ3500
1-T4004
Coaxial
1Set Alpine Type-R Components
1 Set- kicker ks 5.2
1 Set- Kicker ks 6x8
Reciever
Pioneer DEH-P7400HD
2000 Ford F-150 EXT Cab
Clarion EQ
run that at .5ohm just check it to see how hot it gets. as long as your carful things dont just fry up as long as you run them at a ok temp.
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
You can run it at .5 but I personally wouldn't run it if my voltage dropped below 13.5.
When voltage drops more current is needed and that is what will end up blowing your amp. (probably)
I run my dd m3 at .5 daily on less electrical then what OP has and I have never had any issues. DD amps are extremely stout below 1ohm. I watch my voltage and for just daily driving I ensure that it never drops below 13v, and even if im giving a full tilt demo, I try and make sure it doesnt drop below low to mid 12s, and the instant it drops that low, I back off of it.
That said, alot of amp failures are due to the user. Regardless of how stout some amps are below 1ohm, you still need to be prepared to watch voltage, ensure that amp is producing cleanly etc. It helps to have a quality amp to begin with tho.
Team Flex Issues
Low tuning > God
2011 CALI AS1 STATE CHAMP
^^ got youtube so lets see some vids?
2010 Chevrolet Cruze
Radio --- pioneer mvh-200vbt
Front/back --- alpine type s 6.5"
Sub Control --- Pac LC1
Sub Amp --- GZPA 1.4K
Sub --- GZNW 15XSPL D1
Battery - GZBP 12.2500X
  • Who's Online   0 Members, 0 Anonymous, 1746 Guests (See full list)
