ChevyBoy95 Posted July 26, 2014 Author Report Posted July 26, 2014 Well, it works, absolutely no movement in the bracket on start up. Both alts charging in the 14.4 range as well. And 545a of charging BITCHES! Radiator hose is touching the alt, but Im fixing that right after I post this. Also zip tied the wiring neatly to keep it from the belt and flopping around as well. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
n8ball2013 Posted July 26, 2014 Report Posted July 26, 2014 Nice work. Good feeling to have all that juice aint it? THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
Kyblack76 Posted July 26, 2014 Report Posted July 26, 2014 very very nice..... looks and sounds great. Well done. I wish id done mine long ago. If i can get some room, the bracket you did, MAY allow me another one. Maybe a small case hair pin. Any way.. that looks damn good. Nice job. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Kyblack76 Posted July 26, 2014 Report Posted July 26, 2014 Ill pm you for my address, and you tell me what you want for the bracket and troubles, paypal standing by..... Thanks mate. Again, wicked nice work. I like anyone that just dives in, and makes it happen. Did you just go in tandam with the sense and trigger wires? Looking at the alt, the first and third wire in the bracket, so to speak? Appreciate the offer of the template... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
ChevyBoy95 Posted July 26, 2014 Author Report Posted July 26, 2014 Ill pm you for my address, and you tell me what you want for the bracket and troubles, paypal standing by..... Thanks mate. Again, wicked nice work. I like anyone that just dives in, and makes it happen. Did you just go in tandam with the sense and trigger wires? Looking at the alt, the first and third wire in the bracket, so to speak? Appreciate the offer of the template... Pay the 5 buck flat rate and ill send you the .25" MDF template, if you can get use out of it, cool, if not, pass it on. And I talked to mike about it, was really helpful, Yellow and blue are the ignition and constant wire. Template doesnt have the two mounting holes, but it is easy to figure it out, just mock it up and put a 3/8" drill bit through the alt mounting holes and your done. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
Kyblack76 Posted July 26, 2014 Report Posted July 26, 2014 Ill pm you for my address, and you tell me what you want for the bracket and troubles, paypal standing by..... Thanks mate. Again, wicked nice work. I like anyone that just dives in, and makes it happen. Did you just go in tandam with the sense and trigger wires? Looking at the alt, the first and third wire in the bracket, so to speak? Appreciate the offer of the template... Pay the 5 buck flat rate and ill send you the .25" MDF template, if you can get use out of it, cool, if not, pass it on. And I talked to mike about it, was really helpful, Yellow and blue are the ignition and constant wire. Template doesnt have the two mounting holes, but it is easy to figure it out, just mock it up and put a 3/8" drill bit through the alt mounting holes and your done. Under stood. Yes.. (if color code is correct) then yell and blue, is the use. I would be like the FIRST PIN on the plug, and the THIRD one down. Well done. I use my VCM to turn the 350 conventinal on, and use self turn on for the hair pin. Ive had issues with a conventinal and a hair pin guts, working together with external reg. I have the 350 due back to him, for a recase of a large case 370 hairpin. Between the two, i expect NO issues. Anyway,..... Ill think about it, i may have another idea. Thanks for the support either way, and, again,... well done. Now, GO PUSH THE FUCK OUTTA THEM. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
boom50cal Posted July 27, 2014 Report Posted July 27, 2014 Probably the CLEANEST sounding wall I've heard to date. That Brazilian power too On 1/4/2013 at 9:31 PM, HatersGonnaHate said: Wow. 184 posts and I think you're a fucking asshole.
ChevyBoy95 Posted August 1, 2014 Author Report Posted August 1, 2014 Ok, so killswitch is this weekend, so im going to meter the truck to see sort of a reference to what it does compared to the 155.3. Only thing is, it is much hotter now than when i did the 55.3, and dual alts, and some slight changes, but if i can even get something remotely close to a 55, like a mid 54 or something, it would be sweet. Pretty much sold on taramps at the moment though, have demoed it 20-30 times in an hour or two, and anyone who has gotten a demo from me, it is half songs or more, no 10second BS. Have had it get really hot and keep going, takes clipping just fine, and have been beating on it daily (at full tilt) and it hasnt skipped a beat. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
fecupe2001 Posted August 2, 2014 Report Posted August 2, 2014 tuned in for the new score, adding my second alt in a few weeks, keep it up man I´m the SPL Gains topic creator!! wanna get louder?? check this: SPL Gains. Panamenian 2009 & 2010 & 2014 Bass Race 149.9 Champion! 2 15" subs and a 2K wired at 1 ohm, http://www.stevemeadedesigns.com/board/topic/167788-fecupe2001-2-15s-on-a-2k-video-on-page-3/ 8 Massive 15" subs and small power, http://www.stevemeadedesigns.com/board/topic/179296-fecupe2001s-8-15s-4th-order-bandpass-wall/
ChevyBoy95 Posted August 2, 2014 Author Report Posted August 2, 2014 So I metered how I am supposed to. 154.6 which for a ~750 dollar amp, im quite happy. Only thing, is i need more batteries now as well. Probably 2 more d3100s and ill be good. Looking into getting a deep tool box, so i can do like 5-6 batteries along the bottom, amp on top, etc. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
