DC Sound Lab
  • 3 months later...
  • 2 months later...
so when is the level 5 Ts parameters will be released ?
Hertz HSK 165XL
Celestra FA475xDC Audio 3.5KDC Audio level 5 12 inchXS Power 6500 on the front.XS Power 3100 on the back.Knukonceptz 0 gauge an 10 gauge OFC wire.
  • 3 weeks later...
  • 2 months later...
Just wondering if level 4 specs are available yet?
http://www.dcaudio.us/level4.html
Pioneer AVHX-5800BHS
Alt CES 200/270+
  • 6 years later...
2 hours ago, celticwind said:
I realize this is a dead thread however, I am trying to find t/s parameters for a dc audio level 6 18 and the link in this thread is broken. Does anyone have or know where to find good specs?
Did ya check the website or call them
Website doesn't show. I have saved the old specs for a m3? I believe. Hopefully it helps.
Here are the specs I have:
18"
Mounting Depth11.5"
Mounting Hole Diameter16.75"
Outside Driver Diameter18.5"
Motor Width9.84"
Weight85lbs
VC Diameter4"
Displacement.26³ ft
Magnet Weight80lbs
Power Handling RMS/Peak4500/9000
Impedance (Ohm)D.7/D1/D1.4/D2
Sd1217cm²
Vas67.02 liters
Cms0.0325mm/n
Mms588.52g
Fs36.4
BL36.25
Re4.02 Ohm
Le7.5mH
Qms22.43
Qes0.416
Qts0.409
Xmax31.25 mm
Ref SPL @ 1 watt90.7dB
Suggested SealedN/A
Suggested Ported 6³ ft
18"
Mounting Depth11.5"
Motor Width9.84"
Weight85lbs
VC Diameter4"
Displacement.26³ ft
Magnet Weight80lbs
Sd1217cm²
Vas67.02 liters
Cms0.0325mm/n
Mms588.52g
Fs36.4
BL36.25
Re4.02 Ohm
Le7.5mH
Qms22.43
Qes0.416
Qts0.409
Xmax31.25 mm
Suggested SealedN/A
Its a start and will get me in the ballpark for now... thank you very much
  • Who's Online   0 Members, 0 Anonymous, 5823 Guests (See full list)
