budah93 Posted August 6, 2012 Report Share Posted August 6, 2012 I have 2 sa15s in a 98 jimmy. big 3 upgrade 2 batteries electrical system is great. i'm about to do a new amp set up for the subs. I have 2 options that i can get at a very very good price. Should I do 2 kicke zx 1000.1's or should I do 1 Sundown SAZ2500d? I do know they are be over powered but everything will be clean power with out clipping Quote Link to comment Share on other sites More sharing options...
SlamminSL1 Posted August 6, 2012 Report Share Posted August 6, 2012 Sundown. Quote Nothing but old school! 01 Saturn SL1 Sony CDX GT500 H/U Polk DB651 in front doors Profile AMP121 on Polks US Amps USA400 on sub One 12" Cadence Ultra 6ohm Link to comment Share on other sites More sharing options...
bass_stalker Posted August 6, 2012 Report Share Posted August 6, 2012 keep it simple, 1 amp= less headaches. you dont hvae to gain match and what not Quote JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow. Link to comment Share on other sites More sharing options...
Lbox88 Posted August 6, 2012 Report Share Posted August 6, 2012 ^that Quote UBL | Build Log Link to comment Share on other sites More sharing options...
notorious97200 Posted August 6, 2012 Report Share Posted August 6, 2012 Sundown FTW ! I need the same saz 2500 for my btl ! But Kicker amps are very good ones too. Like they said, it will be much easier to run a single amp. If I understand correctly you would use each Kicker at 2 Ohms and the Sundown at 1 ? I hope so. Quote black BMW X1 2.0 l 192 hp OEM head unit, Amplifiers : Audison AP 8.9 amp with integrated DSP and Ampere Audio 1200. Focal ES 100 K in front doors, and Dayton RS 180 for midbass under the front seats. 2 SSA DEMONS 10" subs, in a 2.6 ft3 ported box. SecondSkin Damplifier on front doors, and Luxury Liner Pro for the cargo area. Link to comment Share on other sites More sharing options...
budah93 Posted August 6, 2012 Author Report Share Posted August 6, 2012 i planned to run each kicker amp at 2 and the sundown at 1. I"m getting the saz2500 for $300 FTW hasn't been used yet Quote Link to comment Share on other sites More sharing options...
KenC210 Posted August 6, 2012 Report Share Posted August 6, 2012 I have recently changed from 2 amps too 1... also i had 2 kicker zx1000.1 and went to a single aq2200. It was too difficult to gain match for the fact that the kickers gain does not increase in small increments. You adjust the gain and it was a big difference. I tuned both kickers with dd-1 and looked at voltage with a dmm and seen that one amp was at 48 ac volts and the other was at 52 ac volts. So when i took it down a notch on the one thats was 52 it dropped it to 46. I was never going to really get an exact match on the volts with a dmm. I however did use the bass boost to accommodate the ac volts and go them near spot on but i wasn't sure using bass boost was the right way to do it so i ened up selling them and buying a single amp. Quote Kids Cadi Power Wheel Build2007 Ford Escape Build2012 Toyota Corolla Build 2013 Toyota Tundra Link to comment Share on other sites More sharing options...
Kyblack76 Posted August 6, 2012 Report Share Posted August 6, 2012 Go with the kicker amps,.... then,.. give me the info on the sundown amp....... thanks.,... Quote SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
HunterJohnson Posted August 6, 2012 Report Share Posted August 6, 2012 Where r u getting said sundown amp from?! And yea one big Quote Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass Link to comment Share on other sites More sharing options...
OB/GYN Kenobi Posted August 7, 2012 Report Share Posted August 7, 2012 Sundown unused for $300? You can't go wrong bro Quote 05 Cadillac Escalade ESV Platinum Bumping the stock 9 Speaker Bose FTL... Build in progress (slow progress) Link to comment Share on other sites More sharing options...
