I am looking to paint my car since as of right now it is primed and needs to be painted within the next couple of months.
My question is: Is it more cost effective to go to Maaco after prep-work has been finished or have a buddy of mine do it and I have to buy the paint?
Also if you have used Maaco, how was the paint job and was it worth the money?
95 Acura Integra - 5-speed
Pioneer FH-X700BT
(2) Rockford Fosgate 12" P3
AQ1200d
Rockford Fosgate P1652-S 6.5" components
Rockford Fosgate P1572 5x7"
Rockford Fosgate R400.4
95 Integra Build Here
93 EJ2 Build Here
I won't go there myself, I haven't heard anything good about them.
Edit: I guess the quality may vary depending on the shop though..
Edited by DjCrush
And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle ;)
Chick took 3 shots of Jager, and then, pissed in my mouth..
B5 Passat Build Log
You get what you pay for and if you pay a few hundred that is all about as much work as will go into it, at the very least pay to have it sprayed, sanded and clear coated.
I have seen a few maaco paint jobs that looked great and some that looked like hell so you want to spend what is needed to get the job done correctly.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
maacos are all independently owned. They are all pretty much subpar however there is one near me that does pretty damn good work. They actually do custom jobs and have one of the nicer paint booths in the area. Ive seen a few cars theyve done and they are pretty good. defnitely above maaco average
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Thanks for the suggestions guys. I may just have them spray it and sand/clear coat it myself. I know several people that will be willing to help me out with prep and clear. Just not up to par on the spraying aspect.
Pioneer FH-X700BT
AQ1200d
93 EJ2 Build Here
there are two things i dont do on my own. paint and tint.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
the difference between shitty paint jobs and good paint jobs is prep work, the difference between good paint jobs and fantastic paint jobs is a lot of prep work with high quality paint.
like they suggested, wet sand it bring it to them and have them spray the color on, wet sand it smooth agian and then have them do the clear coat. if you have freinds with the equipment and place to do it for the same cost for the cheap maaco paint job you can get some better quality paint then maaco would use and do it all yourself. start with a door then the other doors and the hood and trunk lid then the body of the car. doing the smaller parts first will allow you to get the right movement down with wasting less paint as you practice.
i would rather do it myself if i was you seeing as to how you would be doing the majority of the work yourself already anyways, the painting part of it isnt even 1/4 the work.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • Who's Online   0 Members, 0 Anonymous, 951 Guests (See full list)
