basshead5280 Posted August 16, 2012 Report Share Posted August 16, 2012 So I'm getting near being done with my box and I need to know what's the best way to finish the inside of the box. What is the best stuff and where can I get it? And also what is a good like bed liner to cover the box with because I dont want to use carpet lol and where do I get that also Quote 1999 Durango Current 2 15" DC level 3 15s kenwood HU Cresendo bc2000 Big 3 upgrade Sky high car audio wire Coming soon Cresendo c1100.4 double din New Build log http://www.stevemeadedesigns.com/board/topic/168661-99-durango-dc-audio-package-in-and-box-almost-done/?p=2464991 Clean Build log http://www.stevemeadedesigns.com/board/topic/171619-dc-audio-durango-clean-build/ Link to comment Share on other sites More sharing options...
ToNasty Posted August 16, 2012 Report Share Posted August 16, 2012 Use a good silicone on all the joints inside of the box. Quote ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers Link to comment Share on other sites More sharing options...
412 CVX Posted August 16, 2012 Report Share Posted August 16, 2012 If it's built right you won't even need silicone. just glue that fucker together and let it rip! Quote Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid. Link to comment Share on other sites More sharing options...
SWIFT Posted August 16, 2012 Report Share Posted August 16, 2012 If it's built right you won't even need silicone. just glue that fucker together and let it rip! Wood glue is not a sealant, no reason other than being lazy not to silicon or use Liquid nails. Quote 2012 F250 Lariat 6.7, lifted on 22's and 35's 4 DSS Ethos 18's walled tuned low 2 Ampere Audio 7500.1's, Ampere 125.4 Rockford Pro Audio front stage 9 batteries, Mechman Elite 370 alt Team DSS, Team Ampere Audio 2014 Meca Mod 3 TN State champ / 3rd place Mod 3 World Finals Link to comment Share on other sites More sharing options...
tacomaguy1 Posted August 16, 2012 Report Share Posted August 16, 2012 I almost never use silicon to seal my boxes....if your joints fit together perfect (which they should), the wood glue will ooze out sealing the joints Quote Team Flex Issues Link to comment Share on other sites More sharing options...
412 CVX Posted August 16, 2012 Report Share Posted August 16, 2012 If it's built right you won't even need silicone. just glue that fucker together and let it rip! Wood glue is not a sealant, no reason other than being lazy not to silicon or use Liquid nails. It's one less thing you have to buy lol. If you make your cuts right and use enough glue., the box will seal its self. Quote Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid. Link to comment Share on other sites More sharing options...
Crandis16 Posted August 16, 2012 Report Share Posted August 16, 2012 if you're really worried about blowing the sucker apart then you can fiberglass it Quote My Red zx2 Build Log My Black zx2 Build Log My Red zx2 UBL Link to comment Share on other sites More sharing options...
b-dubs89 Posted August 16, 2012 Report Share Posted August 16, 2012 if you are worried about your joints inside your box you could do a layer of fiberglass on all you joints , a good layer of glass and resin should ensure a seal as well as add structure . i like bedliner for boxes but i have thought about wrapping a box in vinyl but i'm not sure how smooth that might go Quote Link to comment Share on other sites More sharing options...
Jordan Guess Posted August 16, 2012 Report Share Posted August 16, 2012 rhino liner on the outside (sealed, and looks good) Quote Link to comment Share on other sites More sharing options...
john253a Posted August 17, 2012 Report Share Posted August 17, 2012 as said before, if your cuts are straight, no silicon is needed, for small gaps, make a paste with glue and sawdust shavings and push it in there, if you choose to use silicon on the gaps make sure you push it in to the gap and not just as a nice bead over them, also make sure you use a flexible silicon, otherwise with the movement of the box, and curing it will crack or shrink, and no longer work as intended you also need to be aware that with some silicones you need to wait 24-48hr+ before you can fit you sub, as the fumes can break down the surround of your sub (weather it be fact or fiction, i dont have the money to test it out so i just wait) also no form of paint, of any type will be a long term fix to seal up a box (even if flexi-add is used) Quote Link to comment Share on other sites More sharing options...
