450 seems kinda cheap for a tc sounds lms woofer. yeah it doesn't even have the original coil, which probably took away a lot of the price.
Yeah, the LMS coil is the whole point of getting an LMS sub. Honestly, it's not even a LMS anymore, just a normal sub with a normal coil. The LMS tech in the coil is what keeps the BL so linear and allows ~3" of clean excursion.
Ryan Miskin - owner of RAM Designs
I have my PM's turned off, please email at <script data-cfhash='f9e31' type="text/javascript"> /* */</script>
2200+ designs since March 2011...
alright awesome, ill make a simple box for now until i can get some actual specs on it. i feel like 4 cu ft net tuned to 31hz will be okay. unless someone recommends otherwise?
Don't know why you're shooting for such a huge box, this isn't an HDC3. I'd go for 3.5ft^2, whatever frequency you want, and lots of port area since I'm guessing you want high output.
I'm gonna hate
3.5 cubes is about the best for a tc 15 I've owned about every tc 15 made and 3.5 tuned at 30hz is where they like ...
2000 Suburban 6 runs of 2/0
12 JBL Pro audo mids ,6 timpano audio tweets and 1 Prv compression horn per door
475ah of yin long LTOs
Triple 370 Amp Autotech Alts
mids amps 2  Crescendo Skyway 3ks
compreesion horn amp crossfire 800.4
Tweet amp Crossfire 2000.4
sub amp: 4 Crossfire XT 8ks
Subs: 8 18 in Crossfires in a 4th order
Best Scores at events…
163.5@38hz DBdrag  sealed on the dash… 164.3 outlaw…162.9 Meca headrest
You could honestly get away with 3 cubes, that motor has a lot of force. TC sounds subs have always been small boxed monsters.
Even without an LMS coil, the sub should perform quite well, if it's build properly.
I'd personally run 3.5cubes tuned to 32 with 60^2 of port.
^^^ exactly my feelibgsfeelings
Edited by TeamHT
Maybe email tcsounds and ask for a quote on a recone.
Edited by BobbyG2
*New vehicle and system coming soon.*
how much would i be looking at for a TC coil for it? im kinda bummed now that it seems this thing wont perform like it should. and 3.5 cu ft net im assuming?
Gross volume is meaningless figure for spec use, a brand new LMS-R 15" sub is $433.
  • Who's Online   0 Members, 0 Anonymous, 4658 Guests (See full list)
