DC5K + XL M2's + D2400 + XP 3000: I can't finish build because...
I've got all of my stuff (besides a good alt) ready but I have no clue how to secure the XP 3000 in the trunk spare tire well area. I need your guys help with this. I need pretty much the parts list of what I need to buy exactly and where (lag bolts, rods, etc).
Here is the picture of the trunk spare tire area.
I want the battery towards the rear end as far as possible.
Help please?
Get two peices of althread and drill two holes, get a plate of metal and run the althread threw the floor, and through the plate where it clamps down the battery.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
Make an exact fit of 1/2" mdf and lay that down and set your battery where you would like it to be and once you like where it is then glue and screw some 1"x1" blocks around the battery so it can't slide around and with the false floor on top of it it won't move around or get shifted.
EDIT: Should have mentioned that i mean you'll be covering the whole bottom portion of the tire well in mdf in case i wasn't clear in my description.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
I don't even think I'm going to have a false floor. I'm just going to bolt down the box somewhere on the sides
If you use a metal bracket make sure you have a method to insulate it from the battery posts.
The XP3000 posts are not very high from the battery top and are not insulated well.
I went through the same question.
If the battery shifts for whatever reason, you really don't want a thick metal bracket shorting the posts.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
Dash mounted O-scope
Highs Amp - PPI Art A404
DC Audio DC9.0K
2- DC Audio XL12m2
JUNE 2014 SOTM WINNER
SOTM BUILD:
ive seen your work. how is this a hold up? lol
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
kinda wanna see how this turns out myself so i can mount my batts there.
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
Be safe either way,....... if it was to roll, and make "contact" to your trunk.... bad times...
i just did some some plastic,...Lexan actaully,,...and laid it down,.. bought a 4$ generic/universal tie down to hold it to it....
I used a piece that had enough width and length, that made it hard for the battery to ever turn over...
just a thought..and could give you some inspiration.....(same install, in a spare tire well, with d3100)
Edit- i laid some foam down to keep it hush..... was all....
  • Who's Online   0 Members, 0 Anonymous, 1093 Guests (See full list)
