DC Sound Lab
Box size for xl12s and 7k?
those 3in coils dont like more than about 3k thermally, i see issues in your future....
Agreed. And not because of my bias.
me either, being that i have used every 3in coil DC woofer in the m1 line round wire and flatwire. the flatwound 8 layer coils (3in) start to get hot quick at 3500rms, and i mean HOT if you really dont pay attention. as long as he has the suspension under control (i think 6 spiders will do), all he needs to really worry about is thermal capacity, and 7k is going to push it.
OP, dont be surprised if you have a BBQ mid song at some point.
Thanks for the help when I build the box should I go less than 16sqinches of port per cube for cone control?I want the box tuning at 32hz. My xl18 lasted 5 months on the bc5500. Box was 5.30 cubes and port was 92 sq inches tuned at 36 did a 149.5 on music.
not trying to be a nay sayer, but that XL was not seeing 5500rms. and what you did in 1 box doesnt translate into a completely different box since tuning, airflow/cooling, etc. will all change.
Those things are gonna pop LOL.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
I will agree with you on this one. The most I would put to an XL daily would be 2500-3000w of clean power. The small gain that you will see with more power than that will be so small that it isnt worth it.
yeah kids, i wouldent argue with people that know what they're actually doing.. expecially someone who is a seller of the items and helps build and design boxes for the subs..
down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups
strapping 2 amps together ? like bolting them next together? using bungy cables to hold them down? or wiring separate amps to each sub
I appreciate everything but my bc5500 is staying. Next season I will turn my xls into 4 15s and wall the s10 after i purchase a lvl6 m2 18 for a little fun in a single sub class. I'll just be easy with the knob and keep an eye on the subs like I have been doing. I had the 18xl smoking a couple times at shows giving demos haha.
