Look's good. Any reason you decided to leave the inside bare?
inside of box is bare because i just never got around to finishing it. it seemed i was always climbing in and out to change things. i change something with this box every week it seems.
Team NWSPL
baaudio Build Log
2001 GMC Sierra walkthrough
4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
heres a couple vids of my explorer in action
Team NWSPL
baaudio Build Log
Team NWSPL
baaudio Build Log
Looks good man! How do you like the subs so far?
06 Police TahoeHU- Pioneer 80prsAmp- Crossfire 8kSub- 4 15" Crossfire xs v2sWire- 1/0 Knu/AudiotechnixAlt- 3 Mechman SMD 340sBatts- 6 XS Power 3100s, 2400
I love the woofers. I've had this system running for about 4-5 months now and have only blown 2 which are my own fault. They are really holding up well
Team NWSPL
baaudio Build Log
Nice progress on the setup, you're almost there.
Just got one little concern with it if I may share -
you did:
149.9 db w/ 12 12s on 3 1700s @ 2 ohm each (about 1200 watts per amp)
151.2 db mounted normally and with a chain added (still at 2 ohm)
154.8 db - 8 12s on 2 1700s at .5 each
If the first two were done with 2 ohm, then what did you do with all 12 and the amps being at .5 ohm? You took out 4 and the amp that you said doesn't like .5 ohm.
I think that you should try all 12 and .5 ohm (check and double check everything), and see how well you do. My only thing is that taking out 4 speakers would not allow for a gain in db alone. But you took the 4 out, and then wired down to a .5 ohm load which would yield a higher wattage output from the amps.
Bass Music Producer • Photographer • Graphic Designer
Deep Sector Boom...
you did:
i was having issues with that one amp, put it in my buddies car @ 1 ohm and it would just randomly shut off. its being sent back. and idk if my electrical would support all 3 at .5 either. i drop to high 12s full tilt with two at .5
Team NWSPL
baaudio Build Log
