To strap or not to strap amps?
lt1jerome
I'm about to install two Crescendo bc3500's on two DD9515i's with carbonfiber dust caps. Should I just put one 3500 on each sub or strap them together. Not really sure what the pro or cons of each setup would be. This will be a daily setup playing mostly music. My electrical is a Mechman 340, XS3400 under the hood, Big 3 and two XS D3100's in the rear. Thanks for any info.
ditto. helps spread your rise as well. Strapping is nice because its really less work to set gains but ive had better luck wihtout it.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Really appreciate the info. I didn't know if I would see any power gains or if it would be more efficient to run strapped. Amp per sub it is.
Strapped is better for the subs if you are going to run big power, less current thru the coils.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
i saw some guy at a competition have 2 bc3500s on 4 Fi BL's and had better results when he strapped them together.
they amps stayed cooler and bass sounded cleaner.
(but he did change out his equalizer too, so it could have been that as well)
ive strapped many amps allways been louder more stable and sounded better NOT strapped
only strap if you HAVE to its more for comps for people trying to get all the power to the subs as they can like 4 amps per sub type of shit other than that strapping is only good if its the only way to wire to get your desired ohm load
  • Who's Online   0 Members, 0 Anonymous, 1144 Guests (See full list)
