96 Accord Door Wiring Problem (video added)
VIDEOOOOOOOOOOO
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
No love after video? =[
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
The easiest way to do it is to drill the hole and run the wire. It's gonna be more hassle if you try to drill out the connector and run the wires through it. Just make sure you get a rubber grommet between the wire and the hole in the door.
My name is AdamThis is my Civic Build.7" Samsung Tab 2Kenwood KDC-X896Clarion EQS746Sundown X-15DC 3.5k @2ohmHatersGonnaHate's 02 Civic UBLELD Bypass for Honda Civic/Accord/FitDon's Jeep Grand Cherokee Rebuild
N8ball2013 - i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol
srp365 - If posting were picking up bitches, I'd be going home single tonight
looks like tony montana sneezed in your car.
Yeah I would drill a new hole just for speaker wires from the door into the cabin and run techflex and heat shrink to make a protective shield for the wiring. After you run the techflex and heatshrink just use some silicone to seal around the hole so no water gets in. If do right you would basically have a grommet for just speaker wires.
2013 Dodge Charger
Build Log
1996 Ford Explorer XLT 5.0
Build Log
2005 Honda Civic LX Coupe
Build Log
SMD SUPER SELLER!!!!
My Selling Feedback
Techflex needed? Thats the protective stuff ive seen on power wire under the hood to protect from heat right? So you think a foot of 16guage tech flex and some silicone to seal it up would be all i needed?
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
I would think so, someone correct me if I am wrong but you use the techflex to protect the jacket of the wire and then heat shrink the parts that go into the door holes just for added protection with some silicone to seal her up and you should be fine. Don't see why that wouldn't work unless you can find another accordian rubber grommet boot which would be better because I don't think techflex is waterproof. The biggest thing is to waterproof the are to ensure you're not taking on water because of the new holes.
2013 Dodge Charger
Build Log
Build Log
Build Log
My Selling Feedback
I have this car. I ran my wires through the boot and drilled a hole in the bottom of the connector for the wires.
hey on on that accord door plug there are a couple open spots on the bottom just heat up a screw driver and make hole. doin it this way wont distort plug shape and with boot reinstalled will look stock, hope this helps
Locate the two stock speaker wires in the plug. Cut them out, remove the connector pins, and carefully drill those two pin slots out to accept the larger gauge wire. Or if you really want to, you can try to carefully remove the pins themselves, cut the stock wire off of them, and solder them to your new speaker wires and put them back in. That way you can still have it be easily removable.
My Saab 9000 build
1993 Saab 9000 Aero 5spd
Just Say No To Rear Speakers
Just Say No To CCA Wire
Real Men Drive Stick
  • Who's Online   0 Members, 0 Anonymous, 1093 Guests (See full list)
