Is a LPF on mids needed?
DubNDodge
As of now I plan on running Crescendo PWX6.5 mids along with the FT1 tweets. My question is do you need to have a LPF on the mids? So far I have not found an amplifier, nor an external crossover that has a LPF that will go up to 4khz.
'01 Dodge Stratass Sealed Trunk Build Log
2008 Honda Fit Sport Build Log
On 10/3/2013 at 10:00 AM, ROLEXrifleman said:
Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
shouldn't be needed, they should naturally roll off as they get close to the top of their frequency response.
The only reason you'd want to cross them over on the high end is if you were running into issues with overlap with your tweeters. For SQ yes, will it wreck them if you don't, no.
Some amps have a LPF and HPF that can be multiplied by 10...so say the adjustment is 40-350 for LPF you could push in the x10 and get a 400-3500LPF...Gimme a sec Ill post a link.Im not saying get this amp..i was actually thinking of using it for 2way active...but here is an example..blow up a pic of the side of the amp and you can see the buttons above the LPF and HPF adjustments..
http://www.nvx.com/jad8004.html
MY BUILD *****http://tinyurl.com/gmcbuild*****
Vehicles
2005 GMC Canyon
CB1000r - Currently where any future funds are going. (exhasut,bazzaz, ohlins shock, screen, etc.)
crf250r - Used to be race bike..now I just trail ride..practice at the track on it.
CH80 - Daily beater (when nice weather)best 150$ ever spent. 100+mpg
Sold to:
Skullz - pstone11 - Leo1103 - Volvo 63' - pavelpardo - imnew59585
Shower farts still piss me off.
I think theyre pretty neat. When the water runs down your crack as you let one out... its like shitting in a crockpot.
So is my only choice spending $300+ on an amp that has a 4khz LPF?
Edit: ninja'd ^
Ok
Edit: ninja'd ^
Ok
They're on Ebay for 260-270...probably find em for less but I wasn't saying get that exact amp...I was saying to look for amps with a similar feature and it going to be hard to find a $100-200 amp with LPF and HPF and extended frequency ranges that puts out the power you need for those PWX mids and Tweets.
EDIT FOUND it for 240$ on ebay. Never have had experience with them myself. Read around a little and people seemed to like them.. CEA2006 if that means anything.
Vehicles
2005 GMC Canyon
Sold to:
if you cross over your tweeters at 5k, it probably wouldn't be needed as the frequency response will probably drop off at the higher end of the 83hz-5600hz response of the 6.5s. but if you cross the tweeters over at anywhere lower than that, I'd seriously consider it.
EDIT: you don't necissarily need to cross them over on the amp, you can do passive crossover. Partsexpress has everything you'd need:
http://www.parts-express.com/cat/crossover-components/21
run active with a active corssover. You can always do passive but it wont sound as good and if you spend a little more yoiu get a huge return.
i ran passive for a while and it will do the trick and soiund good. but active is so much easier to tune
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
You don't need a LPF if you don't want to push full RMS to the mids,or if you don't want them to sound decent instead of crappy.
If you're smart you use a LPF, it helps the mid to stay cooler because they don't have to play unnecessary tones and it wil sound better.
I know some people dont like them, but i have never had a problem w/ my FMODS.. They do have a 3500LP model that would work and be cost effective for you.
2000 Chevy Suburban
Pioneer AVHP8400BH
8 - 18" Fi SP4 Subwoofers (fully loaded)
B Pillar 4th Order (75 cubes)
2 - Ampere Audio 8.0 TFE Amps
RF T6004 Amp
RF T4002 Amp
4 - Selenium 8W4P Mids
8 - Selenium 6W4P Mids
6 - Crescendo XST2 Supertweeters
2 - Selenium ST200 Supertweeters
DC Power 320 Alt & Js Ultimate 270
11 - Group 31 Bats
Build Log:
http://www.stevemead...01bdcp-updated/
Team GG
  • Who's Online   0 Members, 0 Anonymous, 1322 Guests (See full list)
