Sundown Audio SA-15s
USAFsound
I just ordered 2 SA-15 D2s and I already have a kicker zxs1500.1 should I upgrade to a bigger amp or will this be fine. I know that the SA-15 is only rated at 600w rms but that is definitely a conservative rating.
Should be a good amp for those
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
Would you have the electrical to back up a bigger amp?
I think if you have the room to get a good box for them it should work well on that amp.
Given you have (half) decent electrical.
I've done the big three and I have a die hard platinum group 34 marine battery under the hood. Everything is 0 gauge and I believe my 02 explorer has a 130 amp alt. I plan on adding a second battery in the back and upgrading the alt soon.
Looks good. I wouldn't run TOO much more power but if you're careful they'll take it like champs. You will love dem bitchez
E34 540iT/6
stick with the 1500.1, you will be plenty happy with that amp/sub combo
2000 Dodge Durango
Subs - (2) SKAR VVX 15 D2's
Box - 7.2 ft^3 @ 33hz, 120 in of port
Sub amp - Digital Designs M2 @ .5 ohm
Mids + Highs - PRV Audio
Mids + Highs amp - Hifonics 2000.4
Headunit - Alpine CDE-100
Equalizer - Clarion EQS746
Batteries - Mopar group 27 + (2) C&D 52ah
Wiring - 1/0 BIG 3, (2) runs 1/0
Alternator - Singer 250A
147.79 dB @ 35hz - burp - sealed on dash
147.47 dB @ 35hz - music - sealed on dash
YOUTUBE: http://www.youtube.com/user/321slapinBass/videos
thats amps perfect for someone that need to ask the question.
just make sure you set it up correctly,
but the amp is only 25% of the system 50% of your lessening satisfaction will come down to the box
  • Who's Online   0 Members, 0 Anonymous, 928 Guests (See full list)
