to fuse or not to fuse, that is the question
Its simple really ... the fuse will pop in overcurrent, not because of voltage ... that's why they call them a "so n so" amp fuse ...
Your volt meter monitors something TOTALLY different than what a fuse monitors ... I thought I made that perfectly clear with my first post in this thread ...
The Fuse is there mainly to protect your equipment from the battery. If something goes wrong and goes into overcurrent or a direct short happens, the fuse will pop when it goes past it's current limitations ... It does not care about voltage in any way, plain and simple
If there is no fuse between your battery and your equipment when something like this happens ... to the battery, its like giving a kid all the candy in the store he can eat ...
That battery source will give ALL ITS GOT until it dies ... something is going to give, and its not going to be your battery. overcurrent produces heat, things are going to warm up and if not taken care of quickly, something is going to catch on fire ...
That is basic Electronics knowledge ...
im gonna be getting some expensive car audio stuff in 2 weeks
ill be ordering 1/0 gauge wire from knu 4 the amps
but ive heard bad things about their fuses
4 me 2 fuse everything right i would need 8 of them
and thats not including the remote and voltmeters
so itd be a little more than $50 4 quality stuff i think
im thinking of getting a fancy battery terminal
do any of them come with fuses built in?
ive heard anl is the way 2 go but idk
and yes, the risk of fire is a good reason 2 fuse
but after 2yrs of running no fuses with no problems
im wondering what would trigger this fire/wire melting?
try 2 learn something new everyday, its good 4 u
thanks 2 everyone 4 input
The fire could start from metal chafing the sheath around the wire. (That's why you use grommets when going through the fire wall, so the metal doesn't cut into the wire)Once the wire is exposed to bare metal, it will draw extreme amounts of amps through the wire, heating up the wire red hot. The the red hot wire will burn through the sheath. Then set interior on fire and BAM. Car fire.
Another case is if something shorts out inside the amp, it could cause the wire coming into contact with the metal on the car.
Here are some good looking fuse holders. I bought 3 of them. They look to be the same quality as the lower line of shok. I will let you know how they look in person once I receive them.
http://www.ebay.com/...-AWG-ANL-FUSE-H
OLDER-/150916386387?pt=US_Car_Audio_Video_Fuses_Fuse_Holders&hash=item
2323514e53
thanks alot i appreciate it
ur link doesnt work btw :(
no u did not say anything about the fuse reading something diff than volts
thats all new 2 me thanks tho
disclaimer if your choosing not 2 read the entire thread:
i have already said im going 2 fuse my upcoming build
i have decided this because
i learned that electrical fire can happen randomly with car audio
and it can happen when the cars not on
thanks 4 those educational posts guys
**actin bad like a kid at six flags**
You are correct ... I reread it. Sorry bro, my mistake
2323514e53
Fixed it. http://www.ebay.com/itm/150916386387?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
School wouldn't let be view ebay. So I figured that link would work. Because it said this __^_ url is blocked. So I copied and pasted that one.
I use fuses so that if one of the power wires rubs through and shorts out or something, it won't create a loop allowing the power from the battery to essentially flow unobstructed.
Please use a fuse, for safety's sake. Put the fuse as close to the battery positive as possible.
I made the mistake of not fusing something once and it was not a fun experience. It's not like you can turn off the car and it stops: it keeps going until you eliminate the short or your battery drains.
It doesn't happen slow either - at least not in my case. Had some 14ga wire going to my volt meter short out and it was only 3-5 seconds before the car was full of smoke
Only time I didn't fuse was when my 7.5k was only 6" away from my batteries, trying to get all I could from it.
Oh, and my alt to batt 1/0 is not fused, but if that somehow shorts, i've been in a pretty bad wreck already LOL.
Always fuse front to back runs at both ends. And now that im not going for numbers, all amps are fused at the battery and the amp, even though the amps have onboard fusing.
SMD Super Seller
My Feedback Thread
Oh: and unless you are drawing the most current your wire can handle, I'd say to use a smaller fuse that's only a slight bit larger than your current draw. Like my wires going to my volt meter (which are now fused) only have a 1a fuse on them.
The big ANL fuses are "slow blow" fuses. Which means that they won't blow immediately if you exceed the current they are rated for. It will take a couple second.
Think of it like the fuses for transformers - the transformer can short out and it will spark and be all nasty for a good 30 second before the fuse blows (that's the big bang you hear)
  • Who's Online   0 Members, 0 Anonymous, 751 Guests (See full list)
