reelfish92 Posted January 5, 2013 Report Share Posted January 5, 2013 Oh and my Crescendo BC3500D that I ran before the bc2k did work on my BTL, never got hot @ 1 ohm. Didn't clamp it then though. Team Flatline AudioBuild Log: http://www.stevemead...-s10-build-log/YouTube ---> http://www.youtube.com/reelfish92 Link to comment Share on other sites More sharing options...
n8ball2013 Posted January 5, 2013 Report Share Posted January 5, 2013 Expected rated at what ever voltage they are rated at. Expect maybe 10you percent more per volt over that THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger. Link to comment Share on other sites More sharing options...
ChevyBoy95 Posted January 5, 2013 Report Share Posted January 5, 2013 I haven't clamped my 2ks but they put out a ton of power for sure. Honestly there is no need to hesitate, best amps I have ever used without question. Then how do you know that they put out: 'a ton of power' ? You wouldn't hear the difference between 4kw and 4.8kw(if they could actually produce that kind of power.). Mecaman, why do you need clamp numbers? Are you using them for SPL purposes? If not, it doesn't matter. well for one, if you have been around car audio, you cant tell slightly when there is a difference if you notice what is going on. My voltage drop is more than with my other 2ks i was using, and even with the extra voltage drop, i am getting more xmax on the same notes, it is louder to ear, and louder on the meter (so yes, i do notice the differences you clown) and EVERYTHING SYSTEM WISE IS THE SAME. Why pick my post apart, try and contribute. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/ Link to comment Share on other sites More sharing options...
aleroking Posted January 6, 2013 Report Share Posted January 6, 2013 I clamped 2k out of my 3500 rising to 1.2 @ 11.5volts 2 fi btl 18s on 2 crescendo 3500s walled in a 2dr 2000 alero build log http://www.stevemeadedesigns.com/board/topic/141663-2-walled-btls-18-on-7k-in-a-2000-2dr-alero/ Link to comment Share on other sites More sharing options...
REVOofRustler Posted January 6, 2013 Report Share Posted January 6, 2013 Here's a clamp sheet I found a little while back for all the Crescendo amps. It looks like they had some crazy rise goin on for these clamp tests though. For what it's worth, I love my BC2000D. It's never gotten more than slightly warm after playing full tilt for 20 to 30 minutes. 2002 Dodge Dakota 4.7 club cab - Sold 2004 Audi S4 Avant - Fi and Crescendo - Stock Bose System - http://www.stevemeadedesigns.com/board/topic/147725-2002-dodge-dakota-end-of-the-road/?hl=%202002%20%20dakota 136.4 Sealed @ 29hz 137.0 Drivers window open @ 26hz Link to comment Share on other sites More sharing options...
SnowDrifter Posted January 6, 2013 Report Share Posted January 6, 2013 I clamped 2k out of my 3500 rising to 1.2 @ 11.5ohm ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
Noel989 Posted January 6, 2013 Report Share Posted January 6, 2013 I think he meant rising to 1.2 ohm 11.5 volts And why do you want to know peak power? Just by the rms And if your using it for spl to compete your going to hVe to do alot of testing Just cause 1 person got xxxx amount of watts doesnt mean all amps are going to do the same Build Log - http://www.stevemead...-cruiser-el-pt/ Link to comment Share on other sites More sharing options...
SnowDrifter Posted January 6, 2013 Report Share Posted January 6, 2013 I think all OP wanted was some assurance that they do rated or more. They are kind of new And my answer is yes: they do ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
aleroking Posted January 6, 2013 Report Share Posted January 6, 2013 around 14volts they will do over rated just keep the voltage up 2 fi btl 18s on 2 crescendo 3500s walled in a 2dr 2000 alero build log http://www.stevemeadedesigns.com/board/topic/141663-2-walled-btls-18-on-7k-in-a-2000-2dr-alero/ Link to comment Share on other sites More sharing options...
kevgnar Posted January 6, 2013 Report Share Posted January 6, 2013 I got [email protected] on 11.2v with a 80 amp stock alt and only 190ahr of batts with my bc3500 rising from .5 On 2/27/2013 at 9:21 AM, Swordlordboy1234 said: Who needs electrical! It's a bc3500... They make power out of hopes and dreams of children 1990 Oldsmobile Cuttlas Cruiser- New build coming soon!! Link to comment Share on other sites More sharing options...
