***Raptor's Altima Build Log! Four Obsidian 15v2's Walled! 5K Page 11 for Rebuild***
Main issue is that the top of the wall is filled, how is he gonna properly install a piece of wood so it actually holds, and stops the flex.
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
Proper prior planning a pole is cool and all but it realistically does not provide the structural strength that a layer of mdf would if you covered the entire roof. Surface area and the strength ofnthat surface are is higher than a pole attached at two points as your contact area is much higher. Pole comes after id you still need strength
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I just went through a few pages. How in the fuck did you build this so fast??
And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle ;)
Chick took 3 shots of Jager, and then, pissed in my mouth..
B5 Passat Build Log
No job lol
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Didn't have a job, lol. And now I do. So no more time between that and 5 classes at college. But yeah. like 10-15 hour days every day working on the car basically.
1996 GMC Sonoma
Four Fi BTL Neo 18's In 2:1 6th Order Bandpass
2 Ampere 5k's @ .5
TEAM FI
TEAM #LITHIUMCANTDEMO
On 10/20/2013 at 0:37 AM, KillaCam said:
Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
the roof in the front of my wall has one layer of mdf....glued around the edges and since the roof is curved, I drilled holes in it once it was up and sprayed foam in the gap
It's super solid, not a lot of flex at all. Easy to do and cheap
Team Flex Issues
Video I took today while waiting for my next class.
http://youtu.be/WAvvJYEIeK4
1996 GMC Sonoma
2 Ampere 5k's @ .5
TEAM FI
Because fuck you physics.
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
  • Who's Online   0 Members, 0 Anonymous, 1696 Guests (See full list)
