Just wanted to share a few pics of what i hooked up today.
The amp is sitting on a 14v XS power battery at 14.6v ish.
Rumor had it that the DD-1 causes damage to a Sundown amp and i am here to say that is complete HOGWASH and just that, a RUMOR. I bought this Sundown amp just to show that it is 100% safe. I will post a new pic every few days showing it playing just fine. I will let it play for an hour or two every day for a week straight if i have to. The DD-1 has been used on the smallest nano-amps to the largest amps on the market juiced up at 18v DC. Every brand including Sundown. It just does NOT cause damage. I used a CC-1 to calibrate the crossover as well. I actually did make a video but the external mic i bought for the GoPro did not record any sound....i messed up an entire day of clips.
Remember, if you want your own Distortion Detector - hit up http://www.wccaraudio.com and use SMDDD1 in the coupon code - save $10 bucks! We are out of CC-1's for another 2-3 weeks due to a problem with parts being stuck in customs....
thanks!
  • Like (+1 Rep) 4
Follow my Tweet (Twitter)
Can't wait to see everyone flame when its proven to not hurt the amp like most of us know is true
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
Lol. It's amazing how people say the DD-1 hurts it. Honestly: it's no different than an Oscope. Use it improperly and the amp will fry because of clipping. That's not the equipment's fault, that's user error.
oh and not to mention, the Xover says "30 -----300hz" please tell me how you plan on hitting 80hz (or 90 or whatever you use) without a CC-1 :D I mean there is other ways but i bet 99% of the people just turn it to where they THINK 80 (for example) is. Good luck on that! :D
  • Like (+1 Rep) 3
I herd the dd1 and cc1 will break your amp and make your music sound like crap.... Respectively.....
From those smart people Kylar referenced
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
Add it to SOTM.
What I do to set my X over's is plug a DMM into my terminals and play a 80hz test tone, and keep rolling up the knob until I start to see the signal voltage dip a bit below where it would be normally.
1996 GMC Sonoma
Four Fi BTL Neo 18's In 2:1 6th Order Bandpass
2 Ampere 5k's @ .5
TEAM FI
TEAM #LITHIUMCANTDEMO
On 10/20/2013 at 0:37 AM, KillaCam said:
Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
