I have a car with a stock 80amp alternator, I will be running an saz1500d. I have a xsd1200 battery in the trunk (stock battery under hood) and stinger 4/0 wiring kit. I recently acquired some soundquest 1/0 cca off a friend for cheap and I was wondering if it would be effective wire for the big 3 in my car?
IS that a stinger 4/0 or 4 ga wiring kit?
1/0 CCA should be fine for you 80amp alt, you should, however, look into getting a slightly larger alternator if you can. 80amp is just enough to run your car.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
x2^^ 4/0 or 4 ga? biggggg difference
02 impala
VM-1
2 dc 12 xl's
RF t2500bdcp
Second skin damp pro
Kenwood head unit
240 mechman alt
d3400 in the front
d3100 in the rear
50ft Rockford fosgate ofc 1/0
  • 3 weeks later...
4/0 ga
cc72738e2a5fa40398fc3c93bbe2dc16_zpsfc80
This is a picture of some of the wire we have laying around at my work bottom is off brand 1/0 cca, 2/0 batt. wire, 4/0 batt. wire, and not sure what the top one is I've heard it called 500 series though.
I think its called MCM...where do yuo work? in a train yard ?
CURRENT SYSTEM:
  • Alternator:
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
    • Mids RE XXX 6.5c
Build Log
My bad i ment 4 gage
  • Who's Online   1 Member, 0 Anonymous, 1655 Guests (See full list)
