RF Amps Don't Turn On
ED2KSR
Wife gets home from work. Says she hasn't heard anything from the speakers all day. I go check and realize that both amps are not powering up. I verified the power connection from battery to fuse(closest to battery), to the fused distribution block, to the power connection of both amps. Everything seems in order. No fuses are blown and the headunit is running.
Have no idea what is the cause. Any advice on what should be done to figure out what the problem could be?
Any help would be appreciated. I'll be on the look out for replies. Thank you.
^lmao.
check remote wire n fuses..... also check ground....
i think there real i was looking through that guys stuff he sells and it looks like he finds stuff at auctions and just sells it
Yea, it looks like someone got the mids about a month ago....shit. If I had a whole Hertz front stage my ears would jizz all over my cheeks.
/ LOL
My Low Budget Build:
Green 1995 Subaru Legacy wagon 147k- $1K
headunit- pioneer premier deh-p650-$25
4 Lead acid batts. 1 up front and 3 in back- vented outside.- $50
4 vvme L11 10"s <- $30 shipped a piece
6 cu. ft box (after displacment) tuned to 32ish hz with 10 inch sonotube. -about $50 all together maybe a lil more
2 aspm 1300 strapped
Selenium 6"s in the front doors on headunit power- for now -$20
quantum tweets in door-for now -$10
boston acoustic 5 1/4 in rear doors- for now-Free
big 3
1/0 and 4awg throughout.
roof sound deadened (not peel n seal ftw)-free
on 80 amp alt (bench tested to put out 100 amps faithfully) <--?-$10 for test
about $430 for everything<----Not bad at all
still gotta add 3 way crossover, amp for front and rear door speakers and maybe eq
I cannot say that I verified that the remote was "powering on" the amps. I assumed that the power is going to get to the amps period as the remote would just be to make sure it turns on/off when head unit is powered on/off. Correct? Will have to verify.
hahaha Kyle. As said, likely it's gonna be your remote turn on for the reason the amps aren't turning on. If they aren't lighting up, it's a remote issue.
Do you have a multimeter
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Nope that's wrong. Amps can have great power and ground connection, as yours do, and without a 12V remote in that is GOOD, TO ACTUALLY turn the amp on, the amp won't turn on.
  • Who's Online   1 Member, 0 Anonymous, 525 Guests (See full list)
