SnowDrifter Posted August 7, 2013 Report Posted August 7, 2013 Im gonna do 43 runs front to back. And 31 neg runs. I'll buy you a keg if you do that ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
Kyblack76 Posted August 7, 2013 Author Report Posted August 7, 2013 Boycotting this thread till subs are mounted Dont blame you. And, im sorry. It is what it is....... I wont add another post, until subs are loaded.... Promise... Why on the neg studs... Guess ill add, that the reason i used a tap, and threaded back through the makings, is, that.. Ive already done the front negs,.. 2 in fact.. Drilled, and threaded, right into the frame. All i did, was drill 2 holes, Tap it, and started driving the fasteners home. Took me 2 seconds to see that there was NO WHERE near enough material on even the frame. I got like 4 threads. I was going to just weld a block to the frame, and tie in.. but.. i again thought,.. hmm.mmmmm this "other way" will be secure 2 ways... Threaded,. then screwed in from the back, then the eyelet, THEN another nut...... that, is secure... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Brandon Jolley Posted August 7, 2013 Report Posted August 7, 2013 Im gonna do 43 runs front to back. And 31 neg runs. So you decided to scale back a little on your bower and ground runs it sound like, only doing 43 and 31 now, you sure that will be enough dude? Alpine CDE-HD149BT Head Unit Hertz HSK 165XL Audison SR4 (Running the Hertz 6.5) Audison SR2 (Running the Hertz Tweets) Ascendant Audio Mayhems 4- 12" (Being Built) DC 7.5K 230 AMP Singer ALT 6 XS-D3000 Batteries (Back) (In the works) 1-XS-D3400 Battery (Front) Lots of SHCA Wire and Accessories.
SnowDrifter Posted August 7, 2013 Report Posted August 7, 2013 Y U QUOTE ALL PICTURES?!?!?! ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
tacomaguy1 Posted August 7, 2013 Report Posted August 7, 2013 Lol j/k That's on the inside of the frame in the back. I was gonna do just nuts/bolts on some grounds right there Team Flex Issues
Brandon Jolley Posted August 7, 2013 Report Posted August 7, 2013 Y U QUOTE ALL PICTURES?!?!?! Because I am a hick from Idaho that like pictures Alpine CDE-HD149BT Head Unit Hertz HSK 165XL Audison SR4 (Running the Hertz 6.5) Audison SR2 (Running the Hertz Tweets) Ascendant Audio Mayhems 4- 12" (Being Built) DC 7.5K 230 AMP Singer ALT 6 XS-D3000 Batteries (Back) (In the works) 1-XS-D3400 Battery (Front) Lots of SHCA Wire and Accessories.
SnowDrifter Posted August 7, 2013 Report Posted August 7, 2013 Good answer LOL ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
DubNDodge Posted August 8, 2013 Report Posted August 8, 2013 Like that bolt idea. If it was me, I would have just put the lug on the side of the bolt head. The way you did it is so much easier, well to work with later. '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
scooter99 Posted August 9, 2013 Report Posted August 9, 2013 Nailed it on the ground lugs. Nice work my friend! Facebook Page: S99Creations 2006 F250 Lariat Build
COLTON94 Posted August 9, 2013 Report Posted August 9, 2013 Im defintly stealing ur ground lug idea. Makes me wish my camaro had a frame lol
