thegr8cody Posted February 12, 2008 Report Share Posted February 12, 2008 (edited) an atomic 5000.1 <a href="http://s139.photobucket.com/albums/q304/thegr8cody/?action=view¤t=S5030547.jpg" target="_blank"><img src="http://i139.photobucket.com/albums/q304/thegr8cody/S5030547.jpg" border="0" alt="Photobucket"></a> <a href="http://s139.photobucket.com/albums/q304/thegr8cody/?action=view¤t=S5030548.jpg" target="_blank"><img src="http://i139.photobucket.com/albums/q304/thegr8cody/S5030548.jpg" border="0" alt="Photobucket"></a> <a href="http://s139.photobucket.com/albums/q304/thegr8cody/?action=view¤t=S5030551.jpg" target="_blank"><img src="http://i139.photobucket.com/albums/q304/thegr8cody/S5030551.jpg" border="0" alt="Photobucket"></a> * Double-sided through hole epoxy PCB * stable into 1 ohm load. * Daisy-chain through output RCA * Two amps linkable function: Output Master & Input Slave * 24 dB low pass variable crossover 30-300Hz * 24 dB subsonic filter 10-60hz * 0 -18 dB bass boost equalization variable control at 45Hz * RCA line input and output * Input sensitivity variable: 200mV – 6V * Tow line input RCA connectors * Phase sift variable: 0-18 degree * Two X Zero gauge power supply connectors * 3 way protection Circuit: over voltage, speaker short and thermal overload * S/N ratio :> 105dB * efficiency over 88% * Tested voltage & THD: 14.4V <0.1% * Signal Noise Ratio: >90dB * Damping Factor: +350 * Operating voltage: DC 10V – 18V power input * size – 10.60”x 2.50” x 23.25 Two amp linked at 2 ohms, 18V 14000w x 1 Two amp linked at 2 ohms, 14.4V 8200w x 1 Two amp linked at 2 ohms, 14.4V 5400w x 1 RMS power at 1 ohm, DC14.4 5000w x 1 RMS power at 2 ohm, DC14.4 3000w x 1 RMS power at 4 ohm, DC14.4 2000w x 1 Edited February 14, 2008 by thegr8cody Quote 1998 gmc sierra h/u:eclipse cd3200 sub:dd9518g d1.5 amp:jl e300/4 sub amp:dd m2a front stage:id ctx65cs dc power 270 alt lots of kicker 1/0 Link to comment Share on other sites More sharing options...
roscoe1129 Posted February 12, 2008 Report Share Posted February 12, 2008 Whos the great one? Quote Some people need a sympathetic pat... on the head...with my hammer Scientia est Vox "In Nomine Patris et Filii et Spiritus Sancti" DONT BE AFRAID TO USE THE SEARCH BUTTON!!! SMD SUPER BUYER/SELLER Link to comment Share on other sites More sharing options...
Aaron813 Posted February 12, 2008 Report Share Posted February 12, 2008 Shoulda gone with the 7000.1 Quote Link to comment Share on other sites More sharing options...
loganberry Posted February 12, 2008 Report Share Posted February 12, 2008 lol way to steal his thunder every1....thats aweosme man..lets see some pix when u get it Quote My F-150 Build GET ON THE BANDWAGON what if they tried messing with the amps when the subs werent louder hahah jk Link to comment Share on other sites More sharing options...
PaulO2288 Posted February 12, 2008 Report Share Posted February 12, 2008 Sweet!!! Thats an insane amp!!! Im giong to be getting 2 7000.1's soon. Do post pics also Quote Link to comment Share on other sites More sharing options...
AI James Posted February 12, 2008 Report Share Posted February 12, 2008 hope you get alot of charging along with it, in another shippment Quote Link to comment Share on other sites More sharing options...
thegr8cody Posted February 12, 2008 Author Report Share Posted February 12, 2008 lol cant bring me down doubt i'll be able to sleep ha ha.i would've done the 7000 but funds limited me to the 5000 there will be plenty of pics trust me.the sub is insane now with only 1600 watts i need to put a few more 2x2's in the box and fiberglass.got some more fuses to get then i should be squared up gotta hook it up but not turn it up all the way i did the big three that helped so much lights dont dim driving and at idle full tilt wide the **** open it stays at 13 and thats 160 amps of current on the hifonics and a 150 watt amp on mids and highs a kinetik 1400 and a POS 105 amp alternator Quote 1998 gmc sierra h/u:eclipse cd3200 sub:dd9518g d1.5 amp:jl e300/4 sub amp:dd m2a front stage:id ctx65cs dc power 270 alt lots of kicker 1/0 Link to comment Share on other sites More sharing options...
thegr8cody Posted February 12, 2008 Author Report Share Posted February 12, 2008 what do you mean charging?i got an alt priced through an automotive electric place its $300 get it the next day direct bolt on also plan on 3 more 1400s the batts will fit PERFECT and i cant say perfect enough at the end of my box and the hatch and my amps will be mounted behind my seats and the box plenty of air ventilation Quote 1998 gmc sierra h/u:eclipse cd3200 sub:dd9518g d1.5 amp:jl e300/4 sub amp:dd m2a front stage:id ctx65cs dc power 270 alt lots of kicker 1/0 Link to comment Share on other sites More sharing options...
AI James Posted February 12, 2008 Report Share Posted February 12, 2008 GL on the build, as stated i hope that your elec holds up. Quote Link to comment Share on other sites More sharing options...
Torres Posted February 12, 2008 Report Share Posted February 12, 2008 lookin forward to pics Quote Link to comment Share on other sites More sharing options...
