Sundown e8v3
Novak
Ok i have a sundown e8 v3 dual 4
And i just hooked it up im running a jl e1200 mono block at 2 ohm and it does not move this sub. Box is .75 cu ft tuned to 33 hz
Ive had the amp set with the smd oslometer thing by a buddy i have 4 ga wires and 30 amp fuse so i know i have more than enough power for the amp but my door speakers are putting out more bass
So i was wondering amp suggestions for a good break in and daily play
Also i have a kicker dx125.2 that was running my 6x9s a while back would that be a better alt to the jl?
I just dont know how sundown like to be worked with yet First sundown
98 honda civic hx build in process
have need
sundown x-12 d4 more sound deadening
sundown saz1500d v2 alternator (mechman)
sky high 1/0 w/ big 3 false walls and fiberglassing
amp rack (half done) and box processor
kicker zx 200.4 (mids/highs)
infinity reference components
trunk lid rear deck and rear quarter panels deadened
kinetic hc1400 under the hood (picking up 2 more late Jan early feb)
check it out http://www.youtube.com/watch?v=1wF0CV2NaX4
November 9th, 2013 metered 140.3 at Midwest audio &detailing sealed on dash w/ termlab (w/ old alpine amp, new amp yet to be metered)
It's a 300 RMS sub and you're giving it 200 RMS, that could be the problem. Also what track did you and your buddy use with the SMD oslometer to tune the amp? Lol
1898070_635754349830843_1457278514_n_zps
I dont know what track i usually just do it by ear but i just couldnt hear the sub
And yeah i know its only 200 wats but from what ive seen if u dont break these subs in they tend to blow
But i cant break it in if its only humming i need it to beat
So i can get my hands on a kenwood kac 1800 w mono. But thatd be over powering it
Itd be 900 at 2 ohm
But thats about the only quality amps i can get ahold of easly around here so im wanting to order one but i just cant decide cuz i know ima get another e8v3 in a month or so
have need
Pos to pos neg to neg
I know these e8v3s are beefy but 200w should move it more
Ive heard the hifonics brz1200.1d is kinda popular but would 600w be a lil much since its only had about 1 or 2 hours of play ?
have need
My fav song on my old set up was psyph morrisons say she wanna andit beat
But this sub was just humming on it
have need
I've got a v1.5 on 200rms
Very close to same sub
And it slams for an 8
I think something is wrong with you sub, amp or the way you set it
Secondly who designed the box and was it built to the design
First check the wireing to sub make sure it is in parrell and not series
Parrell will give you 200rms
Connect all 3 (+) together (2 on sub then to amp)
And the same for (-)
Series will give you 50-60rms
Sub (+) to sub(-) to amp (-)
Sub (-) to sub (+) to amp (+)
Check all the connection on the amp are tight and all the cable is in the connection
Then turn on music and a dmm and check voltage off the terminals at 1/2 and 3/4 and full tilt
Check the setting on the amp
First check its on LPF not HPF or full
The on the LPF check what hz it's set at
It should be 0-250 or 0-something
Set to around 70-100 for now
Then check if you input is set to 0-5v or 5-10v
Make sure you no your output voltage on H/U
And set to that
Turn bass boost all the way down
And gain at around 1/4 up from zero/off
After you do each check you start to find nothing wrong
you will find something is wrong with either amp or sub
If it works and just doesn't get down or drops out in volume on certain feqs/bass notes
check you box
And post some info about it here
Well not hitting
It just wasnt producing anything but maybe like 100 ish db if that
have need
  • Who's Online   0 Members, 0 Anonymous, 466 Guests (See full list)
