its likely leaking between the master cylinder and the brake booster. What do you mean by "going straight to the pads" ? And are you SURE there are no leaks on any of the for wheels ?
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
Possible that your brakes are so worn the brake fluid level has dropped to the point it sucked air and now need to be replaced and bled.
Possible the the master cylinder is going bad and losing pressure.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
With the car off, it still slowly goes to the floor? Might want to check the brake booster as well. Could be a leak in the diaphragm inside the booster, but like said above, check fluid level and bleed the brakes.
  • Who's Online   1 Member, 0 Anonymous, 1651 Guests (See full list)
