Joe X Posted June 21, 2013 Report Posted June 21, 2013 Here is a suggestion: Enclosure Specifications:Fb = 34 HzVb = 1.25 ft^3External Height = 9 inExternal Width = 41.5 inExternal Depth = 14 inPort Width = 3 3/8 inCut Sheet List:* All Dimensions in Inches.* Wood Thickness is 3/4 for all Parts.External Enclosure Parts:Front = 37 3/8 x 7 1/2Back = 41 1/2 x 7 1/2Left & Right Sides:Side 1 = 12 1/2 x 7 1/2Side 2 = 13 1/4 x 7 1/2Top & Bottom = 41 1/2 x 14L Port Internal Assembly Parts:Front to Back = 9 1/8 x 7 1/2Extension = 27 3/8 x 7 1/2 Assembly guide (generic dimensions): Important notes:- The 45s if you want to do them are 2 1/2" wide except the one/ones inside the port, if you want that let me know.- All boxes built outside the vehicle need to fit in their way in not just have the right dimensions.- This box should be operated around subwoofer(s) rated power. If that´s not the case, let me know.- The port needs 3 3/8" of free airspace in front of it for proper operation.- Setting your amp subsonic filter to 28Hz is suggested.
bigmescan Posted June 21, 2013 Report Posted June 21, 2013 if you are going with an SQ type setup 2.5 is to much power......honestly 500 wts is more than enoughnfor that driver. SONY XAV-701HDRF power 400.4 RF power 1000bd 3 Sundown x8's d22004 f150 single cab2 sets of components MB quart 6.5 onx (2 tweets 2 6.5 perdoor)stock batt up fronBIG 3http://www.stevemead...-vid-pg-11-922/http://www.youtube.c.../TheBigmescan74
AI James Posted June 21, 2013 Report Posted June 21, 2013 After 4 You want what? Just 2, I fell you'll be left wanting, That clean look just doesn't work for bass heads, i dont agree at all. i had 4 in mine and the box alignment didnt allow me to get what i wanted out of them so i made another box for just 3 of them. And yes i like things very clean just like the op.
cjvue Posted June 21, 2013 Report Posted June 21, 2013 After 4 You want what? Just 2, I fell you'll be left wanting, That clean look just doesn't work for bass heads, i dont agree at all. i had 4 in mine and the box alignment didnt allow me to get what i wanted out of them so i made another box for just 3 of them. And yes i like things very clean just like the op. holly shit that is clean James. Should of dig around when I was down there last month for the comp. Wanted to check it out. My Build Log- T E A M S U N D O W N A U D I O - 2013 DbDrag WF SS1-2 - 5th Place 154.6db 2013 MECA Mod3 CA State Final Champ 153.4db Powered by: Sundown Audio
AI James Posted June 22, 2013 Report Posted June 22, 2013 my Jetta was parked behind the shop sandwiched in by my wifes Odyssey and Ryans Kia...I never have it out at comps
john253a Posted June 22, 2013 Report Posted June 22, 2013 3 is still 50% bigger then 2 And all my installs are clean and take up no occupant space and always allow for spare wheel access and thing like that, And I speek from experience with the clean look As I always have it and always want more,
greezychef Posted April 20, 2014 Report Posted April 20, 2014 After 4 You want what? Just 2, I fell you'll be left wanting, That clean look just doesn't work for bass heads, i dont agree at all. i had 4 in mine and the box alignment didnt allow me to get what i wanted out of them so i made another box for just 3 of them. And yes i like things very clean just like the op. absolutely beautiful
