Agreene Posted May 19, 2013 Report Share Posted May 19, 2013 hey guys so this is what i have in my car so far,, ( highs and mids wise) belive all components are 4 ohms 1 set of components in my fronts- DD A-W65 component set 1 set of components in my rear doors - skar vxis and one 4 channel amp- skar 85.4 i want to add a set of skar coaxials in my rear deck ( my freind gave them to me or else i wouldnt buy them i already got alot of mids but might aswell if possible !!) so it is possible to add these coaxials to my 4 channel and run this all off my 4 channel ?? i have my components on a passive cross over pic to describe it better?? Link to comment Share on other sites More sharing options...
mothra Posted May 19, 2013 Report Share Posted May 19, 2013 i personally wouldn't. i'd put the 2 sets of skar up front and eliminate the DD comp set. some will probably chime in saying to not eliminate the DD b/c they are better. I'm just giving you my opinion. if nothing changes, nothing changes You don't know what you don't know, till you don't know Link to comment Share on other sites More sharing options...
Kevin M Posted May 19, 2013 Report Share Posted May 19, 2013 You have 4 channels and four crossovers. Get another amp or run them on deck power until you can get another 4 channel for the mean time. 2005 Ford Focus zx4 AMT's and Planars 18" Infinite baffle Link to comment Share on other sites More sharing options...
Agreene Posted May 19, 2013 Author Report Share Posted May 19, 2013 i thought most likely i couldnt but,i had them laying around so why not Link to comment Share on other sites More sharing options...
Agreene Posted May 19, 2013 Author Report Share Posted May 19, 2013 i personally wouldn't. i'd put the 2 sets of skar up front and eliminate the DD comp set. some will probably chime in saying to not eliminate the DD b/c they are better. I'm just giving you my opinion. i got the dd comp set off a local guy for 25 bucks they used to be like 350 dollar components =P they sound alot better, to me the skars are acting as a fade in the rears, Link to comment Share on other sites More sharing options...
bcbrassard Posted May 19, 2013 Report Share Posted May 19, 2013 You would want another amp to run the coax speakers and rear deck location could make your sound stage to high up coming from the rear. Your set up is better off with out them, if anything adding another 4 channel to bi-amp the speakers you have or a 2 channel for highs and your 4 channel for all your mids. Or a active set up vs a passive setup if you a HU with a processing power. Just my 2 cents though. Good luck. Link to comment Share on other sites More sharing options...
john253a Posted May 20, 2013 Report Share Posted May 20, 2013 1st If same all 4 up from off all 4ch And rear off h\u 2nd Or all 4 up front if the same on the 2 ch of amp and other 2ch for rear if amp supports ohm load If different Put in lowest quality in rear door off h/u and amp rear shelf with better ones Put them in trunk for when you demo with trunk open of h/u just for some extra fill Link to comment Share on other sites More sharing options...
TaylorFade Posted May 20, 2013 Report Share Posted May 20, 2013 Do you want it to sound good or you just want it as loud as possible? If it's the latter, just toss em in there and hook em up. Link to comment Share on other sites More sharing options...
98GCLimited Posted May 20, 2013 Report Share Posted May 20, 2013 Id just run all 4 channels to 2 sets of matching components up front and no rear fill. Link to comment Share on other sites More sharing options...
RobertR Posted May 20, 2013 Report Share Posted May 20, 2013 1st If same all 4 up from off all 4ch And rear off h\u 2nd Or all 4 up front if the same on the 2 ch of amp and other 2ch for rear if amp supports ohm load If different Put in lowest quality in rear door off h/u and amp rear shelf with better ones Put them in trunk for when you demo with trunk open of h/u just for some extra fill ^^this^^ or sell the dd set to me. lol BMW 325i Kenwood KVT-647DVD re xxx components re 6.5 FR's 2 RE XXX 12's 2 US amps MD3D's 2 batcap 4k's Link to comment Share on other sites More sharing options...
