kadrek Posted June 2, 2013 Report Posted June 2, 2013 I have a 500 rms mono amp for my sub and a 4 channel 720 watt max, idk the rms, amp for the 6.5 and 6x9 speakers. I had a capacitor in my car before but I took it out when I installed the 4 channel amp because I had heard mixed opinions on them. How do you guys feel about capacitors? I'm pretty sure that I didn't discharge it before I stored it away so how do I go about reinstalling it? It has been sitting for quite a while so has it discharged itself or do I need to? I don't have the bulb or whatever came with it to charge/discharge it so is there anything else I could use? Also, should I probably have a more powerful alternator? My lights dim when the bass hits, would doing the big 3 with some spare 8 gauge that I have laying around help? Thanks in advance! Edit: Also, where would I put the capacitor in regards to the amps? The power wire goes from the battery to the 4 channel and then to the mono. Where in line would I put it?
WastedTalent Posted June 2, 2013 Report Posted June 2, 2013 Don't do big 3 with 8 gauge. Smh.... I'll stop there. Sheena = pedobear
Noel989 Posted June 2, 2013 Report Posted June 2, 2013 Get the mechman cap killer http://www.stevemeadedesigns.com/board/topic/165828-budget-boost-combo-capacitor-killer-kit-only-149-shipped/ Build Log - http://www.stevemead...-cruiser-el-pt/
justin0943 Posted June 2, 2013 Report Posted June 2, 2013 do the big 3 with at least 4ga but 1/0 is better and as for cap put it near both amps an get 2-3f an you should be good 02 dodge ram 1500 reg cab 3rd gen 2 sundown sd-2 d4 soundstream rub1.2500 amp all sky high car audio-fuse,fuse holder,wire,ring lugs and rca flex tech box design by Joe X supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch 04 5.7l hemi motor swap and made it an slt eletric everthing youtube channel-http://www.youtube.c...43?feature=mhee http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
Azagtoth502 Posted June 2, 2013 Report Posted June 2, 2013 http://www.stevemeadedesigns.com/board/topic/157561-capacitors-whats-the-real-story/ pa-pa-platypus sorry not everybody has a companies nuts so far down their throat they catch every drop ball sweat when it falls
Sutliff Posted June 2, 2013 Report Posted June 2, 2013 Amp side of fuse/breaker, & within 18" of amp. Furthermore, you can drain it, if there is anything left in it, with an automotive lightbulb ... The bigger the bulb, the faster the drain. A "194" will take forever vs. a "3457" dual element turn bulb ... Just keep in mind, the bulb will get HOT fast! So if you have some Alligator Clips, use them & lay the bulb on a non-melt-able surface, etc. I do not know what more I can add. Zeke '14 2003 Chevy Monte Carlo SS Vehicle Details & Mod List: http://www.stevemeadedesigns.com/board/garage/vehicle/1703-chevrolet-monte-carlo-ss/ Audio Build Log: http://www.stevemeadedesigns.com/board/topic/143276-2003-chevy-monte-carlo-ss-audio-build-ib-build Pioneer FH-P8000BT Infinity Kappa Perfect 6.1 Fi IB3 (Two 12", 2-ohm SVC) RF T400-2 & T500-1bdCP MechMan S Series 240A XS Power D3400 & D975
kickass audio Posted June 2, 2013 Report Posted June 2, 2013 Yeah as previously said 8ga for the big-3 isnt big enough. I'd only go to at the least 2ga for a stock alternator but 1/0 is preferred. For voltage drop you cant do much with a cap as you need to make power to stop drop and the only true way to make power is to get a high output alternator. You can try to combat voltage drop with getting a bigger and better AGM battery like xs power or other brands (i prefer xs but thats just me) but that will still get voltage drop but it will take a little longer before it gets to a bad voltage level for your electrical system. Caps help with the quick spikes in current draw but not really with voltage drop. If you exceed the abilities of your cap then your voltage drop will be the same as if you had it without the cap. Caps are mainly used to give out fast bursts of power and thats it. As for where to place the cap, they are supposed to be as close to your amplifier as possible. The shorter the run of cable between the cap and amp, the better it will run. Now for discharging the cap idk if yours came with it, most do but there is usually a charge/discharge card that they come with. All it does is have a resistor that is wired to the cap in series when you charge it and then have a larger resistor wired in parallel when you discharge it. You can either do like previously said and hookup a headlight or other light to the cap and let it sit there until it dies out or go to radioshack or any other electronics parts store and get some resistors and wire it up between the positive and negative output of the cap. One thing to make you aware of, if you ever re-use this cap in the future do NOT just connect it directly to the batterys positive and negative. This is a dead short and will make a ton of sparks and can damage your battery. You need to charge the cap up slowly. To do this you can either take an old headlight or a resistor and wire it in series (positive of your battery cable to one side of the light bulb then from the other side of the bulb to the positive of the cap) and just connect the negatives together. When the light goes out you have a fully charged cap. 2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
