Could Using A Speakon Connector For My Subs Make Them Loose Power?
For my new box I'm building I want to use a speakon cable to go from my amp to my box to allow ease of connecting and disconnecting. I was going to use a standard 4 core speakon plug and connect the 1st and second set together to allow better current flow. Could there really be a significant difference between using a speakon and using bolts with terminals? The cable will only need to be less than a metre long.
(Old Car) 1995 Volkswagon Golf MK3 2.0L:
Fi SP4 18 On A DC Audio 3.5K In A PWK Box
Hertz DSK 6" Speakers, Clarion HU
3x Fullriver 120aH AGM's, 225A Alt
2012 Subaru BRZ:
Audison Prima APK 163
Bit One, Rockford Amps, Audison Sub
Not at all, speakon connectors have very low resistance. Less than 2 mOhms.
i shook this one kids hand and it just folded in mine. long story short i fucked his girlfriendso.. yeah..
You want this to happen to you? Give decent handshakes people.
I was gifted with an innate ability to distribute wholesale ass beatings in a timely and orderly fashion.
Not at all. I use them in all the installs I do, and we run 8,000+watts through them on our PA systems.
First Gen Xterra: Always changing
DNX 690HD
RF 360.3
RF T3002
RF T4004
RF T10001bd
Silver Flute 6.5"s
Tang Band 1" Tweeters
Sundown X18 in 7cubes net tuned to 32hz
Trust me .25 Blows your Load.
They are made for it, that's why they are used in most PA systems.
Get the heavy duty ones though, you they will last you for ever and won't fail if you would once forget to disconnect it.
They also fit in the terminal better after disconnecting it a lot.
Thanks guys, do you think I could run all 6000w RMS through a single set of terminals? The 1+ and 1-, and not use the second set.
2012 Subaru BRZ:
i found some that take 4 gauge so im thinking so
REP
