Crazy Voltage drop help
Guys I was wondering how many runs should I do for my SUV. I have 2 Rockford Fosgate 2500-bdcp amps on the subs and a 600-4 on the mids. I also have 4 batteries in the rear with a 270 amp alt up front. Right now I have 2 runs of power to the rear and everything else is grounded in the rear. Please help because I am still getting a lot of voltage drop?
No System......GFY
Check your connections first. Check where your measuring voltage at. Define really bad voltage drop? Your running .. about 7k.. could be a lot of things. Check resting voltage of each bat independent. How are the rear batts connected? Could be a bottle neck
Need more info/pics
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
I am sitting at 14.4 cold, 13.9/14.0 hot when at idle without bumping music. The drop happens when I bang the system. I think its a ground problem because I am only ground(batteries and amps) in the rear and not running 0 gauge ground from front to back?
No System......GFY
how quick does the voltage drop, could need more alt.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
Do you have a charger for your batts ?
If you are banging your system everytime you drive the 270amp alt wont be able to keep up with your potential current draw, leaving your batteries discharged.
Definately check all your grounds first but remember that power has to come from somewhere. You also may want to isolate (to test, I dont mean permanent isolators) each battery, maybe one of them is going bad.
What are your individual batt voltage measurements with car off?
CURRENT SYSTEM:
  • Alternator:
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
    • Mids RE XXX 6.5c
Build Log
What size are the runs? 2 1/0 awg would be good for 700 amps, your probably right underneath that. I would personally run 3 power wires, 3 grounds and also keep the ground in the back.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
How is it grounded in the rear? (pictures maybe?)
Check all the connections, to see if they are still secure.
He won't have a 700amp draw, closer to 400A at full volume. (except if he is playing test tones and pink noise through the speakers)
Offcourse at idle the alternator won't cut it, you need to get to 2k rpms or something.
Bouncing between 13.8v and 12.6v if you turn up the rpms?
That means your amps are drawing more then the alternator can put out, so your batteries are going to get drained.
Dropping to 12.6V isn't that bad, if you don't feel comfortable at that voltage you should upgrade the alternator, no amount of batteries will help you stay above 13v.
Its grounded in the rear only. I have no runs of 0 gauge negative going from front to back so that may be the problem? I have 2 runs of positive going front to back though. All 4 batteries in the rear are grounded in the rear.
No System......GFY
  • Who's Online   0 Members, 0 Anonymous, 732 Guests (See full list)
