2003 Kia Sorento Build log (Pair of Team AA 15's in and playing)
Here's the engine block ground, the stock one I couldn't remove by hand because I believe the bolt was machine tightened, but luckily, there's another insert, which required me to get a 12 mm bolt from Lowes
Fuse holder installed using clear mounting tape so I don't ruin the fuse box cover
Wire sleeve from Sky Craft, and a 2/0 open ended tinned lug with a 1/2 hole to fit the 12 mm bolt
Cleaned with WD 40 to remove rust, sanded down, then grinded down
Alternator cable
Positive cable
Installed
Now charging at 14.5
I decided to keep the factory wiring to
- Use the car when I needed to( like driving it up the ramp to get to the engine block ground and alternator)
- Wiring was weird, and all put together, so I left it alone, and the fuse box had grounds coming from it
- If I decide to sell the car in the future, I can pull out the big 3, and still have a functioning vehicle
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
Word is you have some new tweets on the way for this ;)
Hopefully I get the mids to complement them :)
2003 Kia Sorento
Team Subsonic Lows
doing everything good so far. tuned in to see how this turns out
WTF? Hybrid parking? Really? What the hell is going on with these smug bastards?! I want gas guzzler parking right up front so i dont have to circle the parking lot 40 times and ruin the enviroment.
Thank you guys for the complements :)
Hopefully I can get more done soon, and save up for these mids to complement the tweeters :)
http://www.madisoundspeakerstore.com/silver-flute-woofers-6-7/silver-flute-w17rc38-04-ohm-6-1/2-wool-cone/
2003 Kia Sorento
Team Subsonic Lows
popcorn2.gif.pagespeed.ce.ZE_0vKi6aV.gif tuned in, great work so far.
2003 F-150 Single Cab
Pioneer 80prs
All KnuKonceptz 0ga Wiring (all soldered using Sky High Lugs)
Sky High Fuse holders
Big 3 with redtop
Karma SS RCAs
Eclipse EA4000 for Mids
Rockford Fosgate Punch Pro 6.5s
Crescendo RTS-1 tweets
Audio Technix AT1200.1d for Sub
Soundqubed HDS312
Box 2.65cubes @ 32Hz 6'' Aero port
Stock 130 Alt (looking at a Singer 270 Alt)
  • Who's Online   1 Member, 0 Anonymous, 953 Guests (See full list)
