Karkov Posted June 22, 2013 Report Share Posted June 22, 2013 Someone above talked above using RF constant power amps which would help with rise, then others talked about dropping OHM load to combat it as well. I am running 2 RF sub amps that are rated at 2500 RMS watts @2 OHMs (stable to 1 ohm)......so does this mean I will see more rise due to running at 2 ohm instead of 1 ohm OR since they are constant power amps it will minutely affect it? Honestly, I'm not real concerned about box rise, and I admit i know virtually nothing about it, but I am curious for my scenario exactly what the outcome could/would be for rise. make sense? Thanks in advance 2007 Chevy Tahoe (SOLD) 12 ~ FI Audio X series 10" w/BP option 2 ~ DC Audio 5.0K @0.67 3 ~ DC Audio 5.0K @1.0 2 ~ PPI 3 way sets (not installed yet) 1 ~ RF T400-4, 1 ~ RF T600-2, 1 ~ RF T600-4 4 ~ CT Sounds 5.25" Strato comps (rear fill only) 1 ~ XS Power D4800 1 ~ XS Power D3400 8 ~ XS Power XP3000 160 stock alt, Mechman 370 Elite, 185 DC Power 320+ Sq. Ft. Sound Deadener Pioneer AVH-X5500BHS Youtube: https://www.youtube.com/user/knfjdkghjudfhsgkjdhf/videos?sort=dd&view=0&shelf_id=0 Link to comment Share on other sites More sharing options...
alaskanzx5 Posted June 22, 2013 Report Share Posted June 22, 2013 Someone above talked above using RF constant power amps which would help with rise, then others talked about dropping OHM load to combat it as well. I am running 2 RF sub amps that are rated at 2500 RMS watts @2 OHMs (stable to 1 ohm)......so does this mean I will see more rise due to running at 2 ohm instead of 1 ohm OR since they are constant power amps it will minutely affect it? Honestly, I'm not real concerned about box rise, and I admit i know virtually nothing about it, but I am curious for my scenario exactly what the outcome could/would be for rise. make sense? Thanks in advance The constant power amps do rated at both 1 and 2 ohms. Wiring down to 1ohms could gain a slight amount if power but it won't be a whole lot. If you can wire down to 1ohm for the slight increase in power and it might lower the box rise but I can't say that for sure t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz. Link to comment Share on other sites More sharing options...
Karkov Posted June 22, 2013 Report Share Posted June 22, 2013 Someone above talked above using RF constant power amps which would help with rise, then others talked about dropping OHM load to combat it as well. I am running 2 RF sub amps that are rated at 2500 RMS watts @2 OHMs (stable to 1 ohm)......so does this mean I will see more rise due to running at 2 ohm instead of 1 ohm OR since they are constant power amps it will minutely affect it? Honestly, I'm not real concerned about box rise, and I admit i know virtually nothing about it, but I am curious for my scenario exactly what the outcome could/would be for rise. make sense? Thanks in advance The constant power amps do rated at both 1 and 2 ohms. Wiring down to 1ohms could gain a slight amount if power but it won't be a whole lot. If you can wire down to 1ohm for the slight increase in power and it might lower the box rise but I can't say that for sure NP, kind of what i thought. I am running them at 2 ohm because although rated down to 1 ohm I *think* they are more efficient at 2 ohms? Percent wise i mean, etc.? But i could be wrong, or possibly draw less power? Again could be wrong, lol 2007 Chevy Tahoe (SOLD) 12 ~ FI Audio X series 10" w/BP option 2 ~ DC Audio 5.0K @0.67 3 ~ DC Audio 5.0K @1.0 2 ~ PPI 3 way sets (not installed yet) 1 ~ RF T400-4, 1 ~ RF T600-2, 1 ~ RF T600-4 4 ~ CT Sounds 5.25" Strato comps (rear fill only) 1 ~ XS Power D4800 1 ~ XS Power D3400 8 ~ XS Power XP3000 160 stock alt, Mechman 370 Elite, 185 DC Power 320+ Sq. Ft. Sound Deadener Pioneer AVH-X5500BHS Youtube: https://www.youtube.com/user/knfjdkghjudfhsgkjdhf/videos?sort=dd&view=0&shelf_id=0 Link to comment Share on other sites More sharing options...
bkolfo4 Posted June 22, 2013 Report Share Posted June 22, 2013 DO NOT WORRY ABOUT "IMPEDANCE RISE" FOR A MUSIC OR DAILY SYSTEM. THE SUB HAS A NATURAL RISE AT ITS REAONANT FREQUENCY EVEN WHILE IT IS NOT IN A BOX, BUT IT IS NOT SOMETHING YOU NEED TO ADJUST FOR OR WORRY ABOUT. BUILD A BOX BASED ON THE SUB AND FREQUENCY RESPONSE DESIRED, THEN SELECT A SUBWOOFER WITH THE CORRECT IMPEDANCE TO MATCH THE AMP YOU PLAN TO USE. IF YOU WANT MORE POWER, BUY A BIGGER AMP. I wish there was a clearer way to say it, but I guess there is not since it has been said a million times. Current system: 1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s Previous systems: 2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz. 1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz. Link to comment Share on other sites More sharing options...
Karkov Posted June 22, 2013 Report Share Posted June 22, 2013 I understand, I was just curious. 2007 Chevy Tahoe (SOLD) 12 ~ FI Audio X series 10" w/BP option 2 ~ DC Audio 5.0K @0.67 3 ~ DC Audio 5.0K @1.0 2 ~ PPI 3 way sets (not installed yet) 1 ~ RF T400-4, 1 ~ RF T600-2, 1 ~ RF T600-4 4 ~ CT Sounds 5.25" Strato comps (rear fill only) 1 ~ XS Power D4800 1 ~ XS Power D3400 8 ~ XS Power XP3000 160 stock alt, Mechman 370 Elite, 185 DC Power 320+ Sq. Ft. Sound Deadener Pioneer AVH-X5500BHS Youtube: https://www.youtube.com/user/knfjdkghjudfhsgkjdhf/videos?sort=dd&view=0&shelf_id=0 Link to comment Share on other sites More sharing options...
bkolfo4 Posted June 22, 2013 Report Share Posted June 22, 2013 I understand, I was just curious. It was not directed at you. It just comes up over and over and it just does not matter. Current system: 1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s Previous systems: 2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz. 1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz. Link to comment Share on other sites More sharing options...
BobbyG2 Posted June 23, 2013 Report Share Posted June 23, 2013 Worried about box rise? Cut out the middle man, go infinite baffle. *New vehicle and system coming soon.* Link to comment Share on other sites More sharing options...
AMI CUSTOMS Posted June 23, 2013 Report Share Posted June 23, 2013 TEAM SOUNDQUBED -- TEAM SOUTH TEAM S.O.B. - Founder & Captain 3x Streetbeat World Record Holder 2017 MWSPL 1st place Mayhem & 4th Xtreme 4 2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4 2015 MWSPL 2nd place Mayhem & 4th Xtreme 4 2014 USACI 2nd place Streetbeat 5 - 162.6 db 2014 MWSPL 2nd place Xtreme 4 - 144.9 db 2013 USACI 1st place Streetbeat 4 - 161.9 db 2013 USACI 1st place Street Q+ - 162.8 db 2013 MWSPL 3rd Kaos2 & 4th Xtreme 4 2011 USACI 2nd place MOD 1001-2k - 160.0 db 2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db 2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest Best score to date 164.4 db - Termlab Outlaw Streetbeat 4 - 161.9 db Streetbeat 5 - 162.6 db MWSPL on Dash Legal door open (Music) - 162.5 db Sealed on dash Legal (Music) - 161.1 db - Termlab THE BLACK NASTY CURRENT BUILD & FAB The Black Nasty (6) 15 Rebuild Log 2012 (4) 15 Walled Sierra Build Log Evo X build log Facebook page The Black Nasty Link to comment Share on other sites More sharing options...
CleanSierra Posted June 23, 2013 Report Share Posted June 23, 2013 I would think hypnosis could work also. Just hypnotize that box into NOT rising..... Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
Herokight Posted June 23, 2013 Report Share Posted June 23, 2013 yep box rise and fall can be fixed. take the springs off your ride lol It's safe to say you're gonna fit in just fine here. Lane AKA HeroKight '96 Jeep Cherokee Classic 4x4 R.I.P. Molliboo $200 for new tires, on a jeep!? Is she stealing them or building them with a heat gun and rubber bands? You hear that????That's a category 5 shit storm coming n8: hey you doing today. What's it like being a bitch? you can pm me if you'd like to explain why you arent one. Just like you did for your vs threads. ^^^Rules. Follow them.^^^ Link to comment Share on other sites More sharing options...
