"BOX RISE" is there a way to control it?????
Someone above talked above using RF constant power amps which would help with rise, then others talked about dropping OHM load to combat it as well.
I am running 2 RF sub amps that are rated at 2500 RMS watts @2 OHMs (stable to 1 ohm)......so does this mean I will see more rise due to running at 2 ohm instead of 1 ohm OR since they are constant power amps it will minutely affect it?
Honestly, I'm not real concerned about box rise, and I admit i know virtually nothing about it, but I am curious for my scenario exactly what the outcome could/would be for rise. make sense?
Thanks in advance
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
Thanks in advance
The constant power amps do rated at both 1 and 2 ohms. Wiring down to 1ohms could gain a slight amount if power but it won't be a whole lot. If you can wire down to 1ohm for the slight increase in power and it might lower the box rise but I can't say that for sure
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Thanks in advance
NP, kind of what i thought. I am running them at 2 ohm because although rated down to 1 ohm I *think* they are more efficient at 2 ohms? Percent wise i mean, etc.? But i could be wrong, or possibly draw less power? Again could be wrong, lol
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
DO NOT WORRY ABOUT "IMPEDANCE RISE" FOR A MUSIC OR DAILY SYSTEM.
THE SUB HAS A NATURAL RISE AT ITS REAONANT FREQUENCY EVEN WHILE IT IS NOT IN A BOX, BUT IT IS NOT SOMETHING YOU NEED TO ADJUST FOR OR WORRY ABOUT.
BUILD A BOX BASED ON THE SUB AND FREQUENCY RESPONSE DESIRED, THEN SELECT A SUBWOOFER WITH THE CORRECT IMPEDANCE TO MATCH THE AMP YOU PLAN TO USE.
IF YOU WANT MORE POWER, BUY A BIGGER AMP.
I wish there was a clearer way to say it, but I guess there is not since it has been said a million times.
Current system:
Previous systems:
I understand, I was just curious.
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
It was not directed at you. It just comes up over and over and it just does not matter.
Current system:
Previous systems:
TEAM SOUNDQUBED -- TEAM SOUTH
Evo X build log
Facebook page The Black Nasty
yep box rise and fall can be fixed.
take the springs off your ride lol
It's safe to say you're gonna fit in just fine here.
Lane AKA HeroKight
'96 Jeep Cherokee Classic 4x4
R.I.P. Molliboo
$200 for new tires, on a jeep!? Is she stealing them or building them with a heat gun and rubber bands?
You hear that????
That's a category 5 shit storm coming
n8: hey you doing today. What's it like being a bitch? you can pm me if you'd like to explain why you arent one. Just like you did for your vs threads.
^^^Rules. Follow them.^^^
  • Who's Online   1 Member, 0 Anonymous, 1337 Guests (See full list)
