thermal grease, opinion on this one
ROLEXrifleman
Any opinions on this:
http://www.rakuten.com/prod/cooler-master-icefusion-200g-rg-icfn-200g-b1-thermal-grease-white/215763682.html?listingId=84715137
Just looking for something decent to clean up a couple of old kenwood 823 and 923's. I think a 1023 too.
Anyway, amps just need to get cleaned up and wondering if this is decent enough to get the job done.
TIA
Rolex you sicken me.
Just let me finish my pie
~ Juice
Don't know how it compares , but it's hard to bear Arctic Silver.
  • pa-pa-platypus
  • sorry not everybody has a companies nuts so far down their throat they catch every drop ball sweat when it falls
I'm with ya on the Artic Silver......
i'm just being a cheap fucker right now!! lol
Artic Silver about $20 for 12 grams = $1.66 a gram
This stuff $20 for 200 grams = .10 per gram
~ Juice
I have the exact same thing of that that I bought off newegg. Its a TON of compound so if you don't use a lot then don't waste your time. I used it on my precision power pc2350 that meade just tested for me and it worked great. The amp runs a little cooler than the stock crap that was on it before I changed it out. I used rubbing alcohol on the fets and surface of the amp.
The artic silver is the best compared to the artic silver nanodiamond that I use on my laptop but its costly and only comes in those little syringes.
2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
That's what turned me on was the fact it is a ton of grease. I never know when I come up on these older amps and when I do the thermal grease is always dried out. Quick maintenance and having this stuff on hand will prevent them from over heating. being proactive.
~ Juice
Yeah then in that case if you tend to use it often its worth it. It comes with that tub and inside is a little protective lid that pulls out to keep the grease kinda liquidy (if thats even a word lmao) I keep the pull out top on and screw on the top as well to keep it fresh and prevent it from hardening up. If I were you get something like a small spreader for it as I find it super easy to take this grease and just get a dab of it onto a spreader and then apply it to the surface I need it on as opposed to trying to gob it on a surface and spread it out afterwards. This stuff is not that thick fresh out of the bottle FYI but does a really good job for the price.
Do not use artic silver on electronic parts where it has the potential to "transfer" as it may short some components out.
Ceramic or normal grease (wheel bearing/ball hitch lubricant) work perfectly fine for the most part if you apply it correctly and install the heatsink correctly.
Hammerdown... 1%
I was just doing a little research on thermal grease today at work. id recommend this
http://www.digikey.com/product-detail/en/126-4/345-1011-ND/340309
cooler master makes great products. i wouldnt hesitate to buy some and you only need the thinnest layer so i dont see how you could short anything with it
REP
For all my PCs I use Shin-Etsu.
Zeke
'14
2003 Chevy Monte Carlo SS
Vehicle Details & Mod List: http://www.stevemeadedesigns.com/board/garage/vehicle/1703-chevrolet-monte-carlo-ss/
Audio Build Log: http://www.stevemeadedesigns.com/board/topic/143276-2003-chevy-monte-carlo-ss-audio-build-ib-build
Pioneer FH-P8000BT
Infinity Kappa Perfect 6.1
Fi IB3 (Two 12", 2-ohm SVC)
RF T400-2 & T500-1bdCP
MechMan S Series 240A
XS Power D3400 & D975
  • Who's Online   0 Members, 0 Anonymous, 372 Guests (See full list)
