My amp positive should go to p1 and amp neg to n2 and n1 wired to p2 correct? Its a 1 ohm dvc sub.
'03 Cavalier LS Coup
DC Power 270xp alt
2 Sundown Neo Pro 8's
2 Selenium ST200 tweeters
1 Sundown SAX-125.2
1 CT Sounds 125.2
2 Fi Bl 18's walled
1 CT Sounds AT7000.1D
Here's the best pics of my box I can get. My car is super cramped with it in there haha
DC Power 270xp alt
1 Sundown SAX-125.2
1 CT Sounds 125.2
2 Fi Bl 18's walled
A partitioned wall?
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Do a polarity check on the subs
Just because it says (+) doesn't always mean that, custom subs have been knows to have that happen before
Recheck all the ground and pos and redo if needed
Then get gains reset with o'sope
Build looks clean from what I can see on the computer. I'd definitely check to make sure everything is in phase and the subs aren't fighting each other. ALSO, the grounding possibility, plus gains properly set and THEN see where you are. Basically, everything John just said :D
Yeah ill definitely be checking polarity tomorrow just to make sure. As well as the grounds and all the wiring really. Its so bothersome that they are hardly moving I was really hoping for some monster bass with this set up.
DC Power 270xp alt
1 Sundown SAX-125.2
1 CT Sounds 125.2
2 Fi Bl 18's walled
So you said you have different amps. You mean gou have one kicker 2500 on one whats your other sub amp
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
  • Who's Online   2 Members, 0 Anonymous, 1450 Guests (See full list)
