Big 3 installed and no voltage increase?
Can you get around that ^^^
Pioneer deh-80prs2 10" Tantric Sounds HD's Ported Box Tuned to 33hzSoundqubed 3500.1Hertz HSK 165Tantric Sounds 6.5" Coaxials80sq ft of MurdermatXs Power D3400 & D3100
Sky High Car Audio Cable Throughout
sounds like you have added resistance somewhere in your big 3. How did you terminate your wire ends and what wire are you using ? Did you remove stock wires or add to them ?
I added to them with 1 awg and respliced the ends of the existing wires. I used ring terminals and hammered them on. (is that what you mean by terminate?)
what are you using to measure voltage? and what are you running for amps?
The pioneer deck measures the voltage for me. I have (2) hertz hdp4 (150x4 each), 1 alpine pdx-f6 (150x4) and a Rockford T1500.1 at 1920rms
could the cars computer controlling the amount of charge? Also did you fuse between the alt and battery?
I did not fuse between the alt and the battery... I fused after the battery and before the equipment...you said the cars computer might prevent the voltage?... I have no idea but it better not that would be terrible :D I fix computers for people not for cars
most modern day cars computers regulate the voltage,
When i start my car, i run at 14.1, after a wwhile driving, and it gets hot it goes to 13.6, then after driving for 3-4 hours through out the day, and its really hot outside, like 90+ degrees, it goes to 13.2
thats nuts so when its hot out you will lose voltage for everything. I don't think thats my case though because my change in voltage only happens when I am playing music and it doesnt matter if it is hot or cold. Last thing is my car is a 2003 jeep liberty with a 1 year old alternator and battery. my alternator is rated at 90amps at 2k rpm and I have a yellow top battery.
Thanks for your help.. I think we all might be getting closer to the problem .. possibly a wrong way of installing the big 3? Maybe I wasn't supposed to keep the factory wiring? If that is the case then why would a small tiny 8awg wire interfere especially since I renewed the ends and put them into the jl audio battery terminals? Please help... Thanks again
Should he fuse between the alt and battery? lol............?
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
Should I?
It doesn't hurt anything if you do...if its a really short run (2ft or less) I wouldn't bother but just make sure the wire isn't ran close to anything that it can rub a hole in the jacket or melt from too much heat and short.
Should I?
Also, if you are the dude that chooses to fuse the CHARGE line from alt to battery, you need to charge it at the positive post of the battery, close as possible, and the charge stud of the alt, close as possible.
Think,.... if you put 1 fuse, middleish of the line, and it made contact before or after, the fuse would eliminate one HOT, say the alt. (depending where the fuse was, and where the contact was made)
But, your battery and that line would still be hot.
Feel me?
I'm not exactly sure what you mean by "respliced the end of the existing wires" but i think we are getting down to where the problem is. Hammered on terminals is not a proper solution. Do some search on this forum for proper crimp or soldering help. If you crimp use hydraulic, if you solder use a soldering torch and silver solder and flux. There are no shortcuts to a good termination.
I'm assuming stock alternator and maybe even batteries. At this power level you need additional non-stock type battery(ies) and start to consider and a quality H.O. alternator.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
Should I?
Feel me?
Yea this is very true...I should have mentioned it in my post. Thanks Kyle. :drinks:
you should fuse every positive wire that you add into your vehicle. even the pos/neg for a volt meter.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
Should I?
Feel me?
I'm not fusing alt to battery.. I just care about the one fuse i have right now which protects the system. Now thanks very much for your help and I have 2 last questions.
1. what exactly will happen if I add my stock non gel type battery to my system when I have a yellow top gel type already installed?
2. how much voltage drop prevention could there possibly be gained from hammering versus soldering?
right now at idle its at 13.5-13.4 and when I crank it it can drop to 12.6v. At 2k rpm it is at 13.6v and can drop to 12.8v
  • Who's Online   0 Members, 0 Anonymous, 1313 Guests (See full list)
