Swaggasaur Posted August 29, 2013 Report Share Posted August 29, 2013 it was fixed by turning the gain way down, but now ive lost a lot of clean output from the amp, what could be causing this issue? maybe the HU? but wouldnt i be getting more ground noise then just from my 4 ch? thanks Quote BHE Wall Build TEAM DC Audio TEAM XS POWER1986 Monte Carlo KMC Nova's 20"4 DC XL's W/ PSI Recones2 DC 5k'sPioneer PRS 8010 Audio Technix 6 XS Power D3100's 1 XS Power D3400 Mechman 220a Alternator Link to comment Share on other sites More sharing options...
Swaggasaur Posted August 30, 2013 Author Report Share Posted August 30, 2013 Bump Quote BHE Wall Build TEAM DC Audio TEAM XS POWER1986 Monte Carlo KMC Nova's 20"4 DC XL's W/ PSI Recones2 DC 5k'sPioneer PRS 8010 Audio Technix 6 XS Power D3100's 1 XS Power D3400 Mechman 220a Alternator Link to comment Share on other sites More sharing options...
CJ18 Posted August 30, 2013 Report Share Posted August 30, 2013 RCAs run near power wire possibly. Quote Link to comment Share on other sites More sharing options...
Tebo Posted August 30, 2013 Report Share Posted August 30, 2013 Could be lots of things, test and tune my friend. Like cj said rcas close to wire possibly grounding in the wrong spot. Alt whine is a bitch to find Quote 04 dodge dakota ext cab 4x4 excessive amperage 300 amp alt with MONSTER stud =)sundown z v3 15 in a 4th order on aq2200sundown 100.4 2 way active...2 Prv audio 6mb200 & 2 re XXX tweetersdeka intimidatorkenwood x396big 3 1/0 knu wire back to deka intimidator Link to comment Share on other sites More sharing options...
bassrace Posted August 30, 2013 Report Share Posted August 30, 2013 Start at the amp and work your way to the front. With everything off pull the rca's from the amp, then turn it all back on and see if the noise is still there, if not then the problem is further up. If the problem is there with the rca's out of the amp then the problem is at the amp.(ground, ect.) If you have no noise then put the rca's back in the amp with everything off. Then pull the rca's from the hu with everything off, then turn it all on and see if you have the noise. If no noise then the problem is at the hu. If you have the noise the problem is with the rca's. Try this and report back Quote 145.9@40hz 145.3@34hz big 3 X2 group 34 Deka Group 31 All 0/1 awg jl meta wire Alpine CDA 7894 Orion HCCA D5000 2 AQ HDC312's Crunch gpv1100.2 (for 6.5"s only) AQ pro audio 6.5" - 3 sets AQ supertweeters - 2 sets 2000 Slamry Link to comment Share on other sites More sharing options...
newls1 Posted August 30, 2013 Report Share Posted August 30, 2013 Could be lots of things, test and tune my friend. Like cj said rcas close to wire possibly grounding in the wrong spot. Alt whine is a bitch to find amen... Been dealing with it for awhile, still cant pin it down Quote I love my staffie So anti FACEBOOK it isn't even funny Link to comment Share on other sites More sharing options...
TRTC360 Posted August 30, 2013 Report Share Posted August 30, 2013 ground headunit to the frame, add an extra ground if necessary, ground RCA's to the headunit itself like so make sure grounds at the amp are solid, still having issues? consider swapping out RCA's, at that point i'd look into it being an issue with the amp or an alternator issue, ohhh and I realized you're running a pioneer headunit, it could quite possibly be a blown pico fuse. Quote '93 Firebird Formula V8 H/U- Kenwood eXcelon KDC-X395 Mids/Highs Amp- Hifonics ZXI80.4 Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0 G34 Red Top and a 180amp Ford Alternator www.youtube.com/TRTC360 Link to comment Share on other sites More sharing options...
n8ball2013 Posted August 30, 2013 Report Share Posted August 30, 2013 Pioneer head unit? Quote THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger. Link to comment Share on other sites More sharing options...
