Hello, I am getting a 320A alt to run with my new setup (X2 FI Audio team 15 subs, X2 Crescendo BC3500D amps) and I am wondering what size of fuse I am suppose to put between my alt and battery? And help or opinions would be greatly appreciated.
^^^^^ Assuming you'll be using 1/0 to wire the car, go with 300a fuses. Thats what i use atleast
DC SOUND LAB NUT HUGGER
Currently Own
4 - 18" lvl 6s (m3) w/full Carbon Fiber option
2 - DC 5k
lvl 4 motor
lvl 2 motor
On 8/2/2013 at 8:13 PM, n8ball2013 said:
this is much worse. Its old n8 without the time or patience to hold fucking hands. I'm supposed to be doing school work but yet here i am making sure jr fuck fuck isn't trying to poke the other kids with a stick.
i think you don't need a fuse from the alt to the battery
2010 Mazda 3
*Rebuild Time*
Subs - (2) AA Mayhems 12's
Sub amp - (1) Populus Audio TPA 6500
Headunit - Pioneer App Radio 2
Batteries - XS Power (1) D3100 up front | 6 XP950 rear
Wire - Sky High 1/0 Gauge wires and RCA's and steve's VM1
Alternator - Singer 260 Externally Regulated
Front Stage: (2) PRV Audio 10W650A (4) PRV Audio 8MR500-PhP-4 (4) DS Bullet Tweets | (2) 6.5 Components (Rear doors)
Mids & high Amp : (2) Populus Audio 100.4
Processor: Rockford 3sixty.3
The Build Log : http://www.stevemeadedesigns.com/board/topic/175922-2010-mazda-3-2-aa-mayhems-12-pg14-new-video/page-11
If your regulator or PCM fails (which has happened to me) the alternator will send about 50 volts through anything that's not fused.
Fuses are WAY less expensive than fire trucks.
EDIT: And to the OP's question... fuse to protect the wire and if your system draws more than one run of 1 or 2/0... add another run and another fuse rated to protect the second wire.
Facebook: facebook.com/audioanarchyllc
Instagram: audioanarchyllc
Youtube: youtube.com/bbeljefe
doesnt go high enough for your need
but you should get the point of the length and cable size determine the amperage that the cable can handle
and for 320 youll need 2 runs of 1/0 or a single 2/0 or up
  • Who's Online   0 Members, 0 Anonymous, 3341 Guests (See full list)
