Cheapest way to ACCURATELY set gains?
Brandonbkd
The DD-1 was specifically designed to be the cheapest, easiest and most accurate way to set your gains.
Other than that there really isn't a dependable and accurate way to do it unless you hit up eBay for used equipment (oscope, etc) and even then you're not going to find much at the ~$100 price point.
As was suggested, try to find somebody local or even hunt around for a used DD-1.
Anybody thought about renting DD-1's?
Hmmmmmmmmm
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
Dash mounted O-scope
Highs Amp - PPI Art A404
DC Audio DC9.0K
2- DC Audio XL12m2
JUNE 2014 SOTM WINNER
SOTM BUILD:
DDM or set it up ear. No it won't be perfect. No it won't be accurate.
That's the risk, but just be smart and you shouldn't hurt anything.
Look up your amp to see if it actually does rated. See if someone bench tested it and posted results or look at your or someone elses birth sheet if they are availible for that amp. Once you have an idea what kind of wattage your amp should be putting out use the DMM method but subtract like 5-10% wattage just to be safe.
This is probably as accurate/safe as you can be while being a cheapass.
Dudes...do you guys read? He didn't ask what is the cheapest way to set gains, he said the cheapest ACCURATE way, you both are far off the mark.
The cheapest way to accurately set gains would be to pay someone to do it who has a DD1 or a scope. Some like Sierra will do it for beer. Next cheapest would be to rent the equipment. Next cheapest is to buy that Nano. It does work, I tested it out, and is a favorite of my buddy's Taylor Fade. Then the DD1 or used oscope.
Good luck
Look up your amp to see if it actually does rated. See if someone bench tested it and posted results or look at your or someone elses birth sheet if they are availible for that amp. Once you have an idea what kind of wattage your amp should be putting out use the DMM method but subtract like 5-10% wattage just to be safe. This is probably as accurate/safe as you can be while being a cheapass. You will probably be able to get a bit more out of the amp with dd1/oscope this way, but not much and its a neccesary sacrifice so you don't blow anything up. You can set gains with a VERY basic oscope. Even a super old one from the 80s or something. Audio stuff is a very basic thing for an oscope. The really expensive ones you see are probably ike 350mhz+ models. You don't even need 1mhz for audio.
You should definitely read before posting dipshit. I said best way to ACCURATELY set my gains. I've got enough common sense to be able to set it by ear, but my ears aren't oscopes
FI BL18 Build Log: CLICK HERE!!
2003 Explorer Sport:
FI BL18
SoundQubed 2200 at 0.7ohm
Pioneer DEH-2500UI
Pioneer 6 x 8s
Rockford Fosgate 6 x 9s
5 ft^3 box at 35hz
Lots of Mega Mat
SkyHighCarAudio_zpse6b4e501.png3abb2365-8d29-422d-a446-efa7a74b8dba_zps70e62980.jpgFILogo_zps400b37c1.jpg
Dipshit? What the fuck? How was that warranted? Is this how to talk to people in person who are just trying to help you? Do you get in a lot of fights? I will never understand the attitude some people have online with others.
I read your original post. It specifically says is there a cheaper (accurate) way than buying a dd1 or oscope. Well guess what? Since you said there is no one availible to borrow equipment from there IS NO OTHER ACCURATE WAY. I could have just said that which im pretty sure others already did so no point in posting. Or I could have copped an attitude like you seem to like to do and bitched about you not using the search function to find an answer to a question that has already been answered 1000 times. I didn't though, I offered you the next best thing. It's not totally innacurate like doing it by ear but its MORE accurate than just straight dmming it. There is nothing in between this method and dd1/oscope which is what you really need. Calm down dude.
I came just in time for the butthurts.
Thanks alaskanzx5 I might just do that
I can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows
came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream.
oh lawd.
Turn it up until you smell coil and hear bottoming out.
Just find someone close. 2 hours isn't that bad. Properly set up gains is worth even a 5 hour drive IMO. But by the time you get the gas to drive 5 hours each way it might be right up there with a dd1. There is a reason it was made to be the cheapest way to set a gain properly.
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
I saved up and bought a used one. Honestly one of the best investments I've ever made.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
  • Who's Online   0 Members, 0 Anonymous, 773 Guests (See full list)
