System bogs engine down at idle
When I play my system at full tilt at idle, the voltage drops enough to turn off the car. I just replaced the idle air control and thought that might have something to do with it. I have never had this problem before.
97 crown vic
kenwood hu
big 3
mechman 270 amp alt
1 d3400
2 d3100
hiffonics collosus (bass)
Hifonics Zues (mids and highs)
2 15in kicker l7s
dynamat extreme sound deadner
viper secured
It's a bad idea to play your system full tilt at idle, the alt doesn't not spin fast enough at idle
to make enough power. If your playing your stuff so loud that it shuts the car off your
lucky you haven't burn't up your amps. If you are going to go full tilt, when parked rev your
car a little tell the volts don't drop.
You need a bigger battery bank for that amp to keep voltage up.
2000 Toyota Camry With Sealed Off Trunk
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
Two DC Level 4 m2 12s
80 Mil Murdetmat
Gathering Parts For Wall Build.
Team DC Audio 2014 Member
Spends some.money on electrical
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I have never had this problem before. I have 3 batts...
97 crown vic
kenwood hu
big 3
mechman 270 amp alt
1 d3400
2 d3100
2 15in kicker l7s
viper secured
Do you have a way to monitor your voltage at all times?
Eclipse cd7000
What's your voltage look like when this happens?
It would be good to determine if it's low voltage that is causing your car to stall, or simply the load of the alternator against the engine
just quoting your sig so people on mobile can see
97 crown vic
kenwood hu
big 3
mechman 270 amp alt
1 d3400
2 d3100
2 15in kicker l7s
viper secured
2002 Honda CR-V
Alpine 9887
My Build
Rebuilding...
Second Skin Damp
4 DC XL 15's
2 DC 5ks
Singer 320 amp
6 cap banks
Sky High wire
2 VM-1's
OM-1
all under window line
Team DC Audio
Obama has a law he's trying to pass right now, trying to ban Leo for being a threat to children everywhere.
EDIT: Not in a JP kind of way.
I thought I was going to die from all the jizz filling my ears.
If u have whats in your sig, I don't think your system is your problem
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
  • Who's Online   0 Members, 0 Anonymous, 2819 Guests (See full list)
