Stupid mistake, blew an amp. Help!!?!?! (pics)
soundsystemaniac
Okay. From what I understand, A diode is a diode. there are no specs on that or anything correct? I should just be able able to get a standard diode and resolder it in there right? How could I find the value of the capacitor? and where could I get a new one?
Thanks for the help so far gents!
That would
I got a full board rebuild from AmpMedics on my bc5500 for $280
I wouldnt trust that, to replace the outputs on my bc3500 was $247 from db-r, If you want I'll pm you with what db-r told me about amp medics
That would be good. thanks
Some diodes will have a higher voltage rating or lower/higher voltage drop, so you need to be as close as you can to the original.
Just because that diode looks smoked, it doesnt mean its the only thing wrong, so you replace the diode turn the amp back on and poof that magic smoke comes back, and possibly burning up even more components.
Not to mention you got to fully disassemble the amp, which is not hard, but what is hard is getting the spring clips back over the mosfets without damaging or weakening the spring clip tension, which could result in less pressure holding the mosfets to the heatsink which could cause the looser ones to over heat and blow. sometimes its even a bit hard to get the spring clips off.
Works perfectly
MY BUILD
1998 Ford Explorer 2dr sport
1/0 Big 3 1/0 everything
Alpine cda-9884
Crescendo CZ components
(2) Crescendo bc2000's
(2) Jolt 150ah
(2) Yellow top optimas
(1) Juicebox black cherry addition
(1) Mechman 270 avbm
miss my bc5500 and (4) 15's
You know why people are ass holes online but not in person? Because getting punched in the mouth hurts.
the cap is a ceramic capacitor try to wipe the smoke to see any number on it and the same as the diode
02 dodge ram 1500 reg cab 3rd gen
2 sundown sd-2 d4
soundstream rub1.2500 amp
all sky high car audio-fuse,fuse holder,wire,ring lugs and rca
flex tech
box design by Joe X
supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch
04 5.7l hemi motor swap and made it an slt eletric everthing
youtube channel-http://www.youtube.c...43?feature=mhee
http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
always wire with power off and fuses out.I learn from you guys.
2009 bmw 5 series
Head Unit Stock
Amplifier-JL Audio JX 360/4
Processor- Audiocontrol LC6
hope you get it fixed
2009 bmw 5 series
Head Unit Stock
if the amp was off he wouldnt have had an issue, but it was playing.
  • Who's Online   0 Members, 0 Anonymous, 351 Guests (See full list)
