Project D.G.A.F - the SMD Tercel - 4 15" LVL 5 Walled - 16v, DC Audio 9.0k's 18v EARLY SPL results pg 28 new Podium Page 33
Throw a layer of tape on the windshield, then do a couple layers of fiberglass on it, peel it off, then when the windshield blows, ta daaaa you can make an extreme car windshield :)
2004 Bagged Trailblazer
(4)18" Sundown Nsv3s
(4) Taramps HD10000s, Taramps DSP3000, Lanzar opti 250x2, AB 100x4
(2)DC power SP 270s, (14)XS Power d3100s, (1)d6500
Just use some tint. Itll hold it together
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
2 175a per block (for a 350a total value) .......and 3 of those pairs per each DC Audio 9.0k
Also got some Skyhigh 4ga (red and black) OFC for the smaller amp (and future projects)....as well as some 12ga OFC speaker wire.
which fuse holders are those, i dont think i saw em on the site
Edited by bass_stalker
Can't wait til this get's hook up! Hey Steve, if you need more room under the car or free up some weight, you can drop the factory gas tank, and install a half gallon (or less) under the hood of the car and run an inline fuel pump, like some of the drag cars use.
Arkansas Based Car Audio Bass Music & Test/Competition Producer
Now Streaming worldwide on: Spotify
Worked on the battery rack a little bit. Its welded in critical spots and just tacked in other spots (for now). Once i am 100% sure its going to work, i will get busy and lay some final welds down everywhere else. Anyway, here is just a few pics of where i am at.
I got the depth i was looking for, about 8"......but decided to make a flange for the top. This way it has something to support it. Once this is done i weld it into the car, skin it with sheet metal and water proof it. Then the batts go in and i can start buss bars and some wiring.
It worked out good. Dropped right in. A little tight but that's totally ok :D
Follow my Tweet (Twitter)
Looks freaking titts Steve! It's always the little things you do that make your builds unique.
thanks :D
i am doing a lil more givin' a fuckin' then i planned on. First the hole....that was total dgaf. But the drop down rack will be g.a.f. because i can't have garbage work no matter how hard i try :D
  • Who's Online   1 Member, 0 Anonymous, 717 Guests (See full list)
