100-125rms through 20ft 16GA OFC SHCA Wire OK?
Yes you will be fine. Shca 16 is at least 14 Awg so look at that for reference
*** SuperSeller Status Verified *** ( http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers/ )
"kevosinn's" astro van
8 custom Sundown Zv4 18's
4 Sundown scv 6000's
CNF Distribution CNC parts
Skyhigh wire
some batteries
SMD Meters and tools used on the install
http://www.stevemeadedesigns.com/board/topic/172877-kevosinns-vanwest-coast-skyhigh-car-audio-vehicle/
16,000 watt walled silverado build.
http://www.stevemeadedesigns.com/board/topic/161965-walled-silverado-4-hdc4-15s-4-crescendo-3500s-and-much-more/
8,000 watt 1999 Subaru legacy outback. Build log here: http://www.stevemead...ru/page__st__60
TEAM CNF Distribution
You should fine,I don't have any of the SHCA 16 ga but if it's anything like their 14 ga then it's bigger than the average 16 ga wire. Their wire seems to be a little oversized which is great so you're basically running 14 ga to the comp set.
I believe it will cut on you thoe :/
Thats what i experienced on a lincoln navigator at only less than a 100wrms and the wire was 14G aprox maybe 7 fts
I recommend you going 8Gauge at least that will help ((:
Ummm no.
It is a/c and not d/c so the wire will be fine running your comps with it.
The chart is only good for D/C runs, with A/C you'll be able to use much smaller wire and run it longer.
Correct me if I am wrong, I believe that an amplifier fed by a direct current (DC) battery will also output a DC signal to the speaker. That is why there is a positive and negative terminal on your amp . You are correct that the chart is for DC current. Alternating current (AC) is what is in use in your house.
DC power stops at your amps power/ground inputs, everything out is AC current. AC in your house has to have a ground as well, even older houses with old wiring with no ground works because your neutral & ground wire go to the same ground bar in your house panel. sorry bout grammar but I'm drinking & don't gaf right now. lol
The amp is fed by ac voltage from the rcas, it then amplifys that and outputs it to the speakers. Dc current is what is used to make this process happen. Dc current is flat. No sound. Ac current has waves. Which produce sound when hooked to to a speaker.
1999 GMC Yukon, 6 PSI platform 5 18's, 4th order bandpass by BHE, Taramps,
  • Who's Online   0 Members, 0 Anonymous, 1623 Guests (See full list)
