KickersintheTrunk Posted November 4, 2013 Report Posted November 4, 2013 Is an amp without the subsonic feature a bad amp? Just wondering if using an amp without subsonic is potentially harmful. Check out my Youtube channel www.youtube.com/user/ologiic
Tribe Called Bass Posted November 4, 2013 Report Posted November 4, 2013 if you watch your gains and don't have a 27hz box, i personally wouldn't worry.
Guest Posted November 4, 2013 Report Posted November 4, 2013 no. you just need to learn the songs you play and control the volume knob
KickersintheTrunk Posted November 4, 2013 Author Report Posted November 4, 2013 no. you just need to learn the songs you play and control the volume knob Yeah was thinking about staying on top of the volume, thanks for the help bud. Check out my Youtube channel www.youtube.com/user/ologiic
Broke_Audio_Addict Posted November 4, 2013 Report Posted November 4, 2013 What amp is it? some amps use the high pass as the subsonic. Also x2 on the knowing what songs you play. If you don't play to much below tuning you should be fine. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
KickersintheTrunk Posted November 4, 2013 Author Report Posted November 4, 2013 What amp is it? some amps use the high pass as the subsonic. Also x2 on the knowing what songs you play. If you don't play to much below tuning you should be fine. It's a Pioneer Gm-d8601 Check out my Youtube channel www.youtube.com/user/ologiic
john253a Posted November 5, 2013 Report Posted November 5, 2013 not 100% but think that amp a factory set one @10hz but could be wrong i no kicker are factory set non adjustable at 24hz
KickersintheTrunk Posted November 5, 2013 Author Report Posted November 5, 2013 not 100% but think that amp a factory set one @10hz but could be wrong i no kicker are factory set non adjustable at 24hz The kicker subs are set to not go below 24 hz? Sorry you confused me. Check out my Youtube channel www.youtube.com/user/ologiic
john253a Posted November 5, 2013 Report Posted November 5, 2013 not sub there amps have a built in subsonic set at 24hz i was saying i think the 8601 has one but set to 10hz
