audiofanaticz Posted December 26, 2013 Report Posted December 26, 2013 ^^^ Kind of like the people that think well if the amps wire only needs a 150amp fuse, and i put in a 300 amp fuse, it will get more power
ROLEXrifleman Posted December 26, 2013 Report Posted December 26, 2013 If your single run can flow the needed current then don't waste your money. The amp can only use what it needs. Having more on tap does nothing. Rolex you sicken me. Just let me finish my pie ~ Juice
OrionStang Posted December 26, 2013 Report Posted December 26, 2013 If your single run can flow the needed current then don't waste your money. The amp can only use what it needs. Having more on tap does nothing. Then why do fuckers run 10 D3100s on 8k? Just playing around to make a point. This forum is in love with overkill. Run triple inputs, 2 270XPs, and as many extra batts as you can fit, for a 7.5k LOL. SMD Super Seller My Feedback Thread
Miguels Posted December 26, 2013 Report Posted December 26, 2013 what if you are running below 1ohm. lets say .35 ohms, will they help with more amp draw? my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
mrd6 Posted December 26, 2013 Report Posted December 26, 2013 I saw no gain on my SAZ3500 when i started running duals... My Build Log: http://www.stevemead...-sundown-power/ Team NorthWestSPL
Skullz Posted December 26, 2013 Report Posted December 26, 2013 If your single run can flow the needed current then don't waste your money. The amp can only use what it needs. Having more on tap does nothing. Then why do fuckers run 10 D3100s on 8k? Just playing around to make a point. This forum is in love with overkill. Run triple inputs, 2 270XPs, and as many extra batts as you can fit, for a 7.5k LOL. They run that many batteries to maintain as high a voltage as possible before dropping to unsafe levels. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
soundstream15 Posted December 26, 2013 Author Report Posted December 26, 2013 Great advice! Thanks guys
MACnonsence6 Posted December 26, 2013 Report Posted December 26, 2013 what about reducers i was gonna use 1/0-4 for the sex apeal I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha.
ROLEXrifleman Posted December 26, 2013 Report Posted December 26, 2013 If your single run can flow the needed current then don't waste your money. The amp can only use what it needs. Having more on tap does nothing. Then why do fuckers run 10 D3100s on 8k? Just playing around to make a point. This forum is in love with overkill. Run triple inputs, 2 270XPs, and as many extra batts as you can fit, for a 7.5k LOL. Because of 45 minute demos with the Tahoe off for underage girls, that's why!! lol Rolex you sicken me. Just let me finish my pie ~ Juice
SojiaRaggs9000 Posted December 26, 2013 Report Posted December 26, 2013 If your single run can flow the needed current then don't waste your money. The amp can only use what it needs. Having more on tap does nothing. Then why do fuckers run 10 D3100s on 8k? Just playing around to make a point. This forum is in love with overkill. Run triple inputs, 2 270XPs, and as many extra batts as you can fit, for a 7.5k LOL. Overkill, whats that? * Eclipse CD3200 with PAC SWI-CAN2 and SW-ECL2 Steering Wheel Controls Interface* Pioneer D-Series Mids and Highs ( Fronts: TS-D1702C; Rears; TS-D1702R and Dash; TS-D1002R )* Rockford Fosgate PBR300X4 ( Mids and Highs Amp )* DC 3.5k with Dual Inputs; Custom Plexiglass Backing ( Sub Amp )* Rockford Fosgate Balanced Line Driver * One FULLY LOADED ~ 10" DC m2 XL* Custom Built Carpeted Ported Box Tuned to 32hz. Single Chamber With Volume of 1.44618³ ft ; 1.13216³ ft After Displacement* Custom Built Carpeted Trunk Wall with Added Fans for Amplifier Cooling* MechMan 240a High Output Alternator * KnuKonceptz Krystal Kable RCA Cables* Upgraded Electrical With 1/0 KnuKonceptz Kolossus Fleks Kable and 1/0 Sky High Car Audio Cable* Five Exide Orbital ORB34M Marine 12 Volt Batteries* PowerMaster XS D3100 12 Volt Battery My 2008 Chrysler 300 Limited - SuperCharged 3.5L V6 - UBL My Old 2005 Ford Taurus - CarDomain - Vehicle Was Sold
