soundstream15 Posted December 26, 2013 Report Posted December 26, 2013 I'm running a SQ2200.1 and was wondering if dual inputs are actually worth it.
MACnonsence6 Posted December 26, 2013 Report Posted December 26, 2013 same question with the ct sounds 4k I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha.
Karkov Posted December 26, 2013 Report Posted December 26, 2013 There was supposed to be someone on here doing some testing on those exact questions using a Amp Dyno but I can't recall if the tests were ever completed or what the results were. Have you guys tried searching for this topic? I own them and use them for the peace of mind. IMO if your electrical is lacking in any way shape or form then dual inputs could prolly not help to their fullest potential anyhow. 2007 Chevy Tahoe (SOLD) 12 ~ FI Audio X series 10" w/BP option 2 ~ DC Audio 5.0K @0.67 3 ~ DC Audio 5.0K @1.0 2 ~ PPI 3 way sets (not installed yet) 1 ~ RF T400-4, 1 ~ RF T600-2, 1 ~ RF T600-4 4 ~ CT Sounds 5.25" Strato comps (rear fill only) 1 ~ XS Power D4800 1 ~ XS Power D3400 8 ~ XS Power XP3000 160 stock alt, Mechman 370 Elite, 185 DC Power 320+ Sq. Ft. Sound Deadener Pioneer AVH-X5500BHS Youtube: https://www.youtube.com/user/knfjdkghjudfhsgkjdhf/videos?sort=dd&view=0&shelf_id=0
soundstream15 Posted December 26, 2013 Author Report Posted December 26, 2013 I'm not dropping below 13.7 I got the dual inputs, I just need wire but if it's not worth it then I won't it lol
OrionStang Posted December 26, 2013 Report Posted December 26, 2013 It doesn't hurt. So if you can afford them, get them. SMD Super Seller My Feedback Thread
n8ball2013 Posted December 26, 2013 Report Posted December 26, 2013 Doesnt hurt but its questionable how much if any it helps THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
Kyblack76 Posted December 26, 2013 Report Posted December 26, 2013 In my shit... dual's do nothing. If you gained from a dual, then you were lacking before. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
audiofanaticz Posted December 26, 2013 Report Posted December 26, 2013 It was cj that did testing. and they didnt help. Most people with a rear battery by their amp(s) wont see a difference since your amps power wires are so short and a 4 foot power wire can handle so much amperage (compared to the normal rating of about 300amps at 17ish feet). the only time multiple inputs on your amp would help you out is if your battery is in the front of your car, and you have a huge amp in the rear, at that point running multiple runs to that amp is needed to reduce the voltage drop per run of wire. Perfect example are street a and b cars for db drag, 1 battery, 2 big 10,000 watt amps powering 2 12s off one d3100 or similar size battery under the hood with the car off and the stereo just goes burrrrrrrrrrrrrrrrrp
audiofanaticz Posted December 26, 2013 Report Posted December 26, 2013 In my shit... dual's do nothing. If you gained from a dual, then you were lacking before. This... I also noticed those that claim duals made a huge difference are also those that say ofc wire is the best wire and running multiple runs of cca is a waste of money even tho its cheaper in most cases and cant handle way more current.. but yet they put these dual input blocks made out of aluminum on their amps and batteries, only to say aluminum wire is junk.. laughs
ROLEXrifleman Posted December 26, 2013 Report Posted December 26, 2013 If a single delivers the current being consumed by the amp then don't waste your money. Having a dual there only means that more current will be available but the amp is still gonna draw what it needs and that's it. It's not like the dual is force feeding it more current. It's not a super charger or turbo that force feeds. Another way to put it is like having a Throttle body that can flow crazy stupid high CFM. If your intake cant handle x but your TB can flow y your still limited. Rolex you sicken me. Just let me finish my pie ~ Juice
