pro's & con's? Needed or not? Opinions!
Running one on my ground for my T-1500, if I had offset reducers like that I would have 0 gauge on both
25d9cf71-fff8-4b67-a8f5-28c80d5ea859_zps7d3fe7f6-90c4-4939-b709-43f0e5812212_zps
2018 Honda Civic Sport Hatchback (build in progress)
NVX Sound Deadener (Front Doors)
Stinger FAST Rings
Stock Electrical
SSA Evil 6.5's Front Speakers
Stock rear speakers
MB Quart ONX4.80 speaker amp
Rockford Fosgate T-1500bdcp
DC Level 4 12" D1 @ 2-ohm
Box In Design Stage
Stock Radio
My Build Log
Just make sure they don't touch!
Good point. When you go to install it in your car it would be better to connect the (empty) reducers to the amp first then put the wire in. To be safe.
And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle ;)
Chick took 3 shots of Jager, and then, pissed in my mouth..
B5 Passat Build Log
Wires will be bolted down and i will put a small piece of black foam between them to protect again that.
That was the Plan. Trust me!
I shrink wrapped mine with that skyhigh 1/0 shrink wrap, looks nice and gives me piece of mind, lol
Stinger FAST Rings
Stock Electrical
Stock rear speakers
Box In Design Stage
Stock Radio
My Build Log
Crazy cause I am about to do the same with my amps. Tool
maker offset adapters to go from 1/0 to 4. Can't hurt. I guess I will see by voltage drop.
80prs
Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier
Incriminator IA 10.1
Focal PS 130v 5.25 (doors)
4" Faital pro Neo (kick panels)
3" Faital pro Neo and focal tweets( dash)
DC Audio level 3 12"  custom box designed by joex built by me
AGM front, XS 750SE batteries rear
DC 180 alt
99 Toyota Tacoma extra cab
http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
That was a thought i had was to shrink wrap the negative side for protection.
If your negative side contacts another ground, like interior metal, you are ok. If your positive wire does the same, bad news. So I would protect both, but if you're only going to do one, I would wrap the positive.
Thank you sir, i will take your advice. Maybe wrap both just to be safe!
  • Who's Online   0 Members, 0 Anonymous, 3374 Guests (See full list)
