What would be more beneficial to me ?
Okay, so I have a mechman "260" amp alt, 850 cca agm batt up front, big 3 done, and 2 92 ah cell tower back up batterys in back. Would it be more beneficial for me to add a 2nd run of positive from alt to rear batts, or do a run of negative from the negative of front batt to rear batt negative ? Oh sub amp is dc 2k and I only drop to like 12.5-12.6 at idle wangin away at full tilt on a dc lvl5 18.
Current setup in my 96 Hoe
Hu - Pioneer DEH-80prs.
Amps - (4) Crossfire C5 1700D's, MTX Thunder 5604(mids), PPI Art 300.2 (tweets)
Batts - 4 91ah rear batts, 50ah batt up front.
Subs - 2 Crossfire XSv2 18's
Alt - Singer 330A
Front stage - Random JL & Eclipse mids, Eclipse tweets
Don't even do the negative run. Prolly don't even need to do the positive run either but it wouldn't hurt anything (especially if you upgrade your RMS wattage later one). That is really not that bad of voltage drop. What is it like at 2k RPM? Do you play at idle a lot? What is your voltage like on vehicle start up? How about when hot with no stereo on?
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
I'd add a second pos and double up the neg to where you have it now. You might not need it but It definitely couldn't hurt. I agree you don't need to run a neg from the front though.
CARS
14 Sierra crew cab daily, Small build coming one of these days
69 C-10 fleetside in many pieces, won't be done till the end of time
Last car '12 Focus with build log
http://www.stevemeadedesigns.com/board/topic/165619-2012-focus-btl-15-crescendo-sundown-audio-control/
Also what kind of batts do you have? Could maybe have something to do with it. Better quality batts yes exspensive but also may save you in the long run.
05 Escape
2 Ascendant Audiio Mayhem 15s dual 1
Populus Audio 6500 (the only one around )
1/0 SHCA OFC
XS 3400 under the Hood
XS 3100s in the rear X2
Pioneer 80 Prs
Pac
Prv mids and highs
2 8s per door 1 tweet
It really seems no different at 2k rpm, voltage just drops slower. And no, not usually. Voltage is usually 14.2-14.3 on start up. Sometimes even 14.7 before it warms up lol. And hot is usually 13.7 - 13.8
Alt - Singer 330A
Wait, you drop like 2 volts?!?
Read my sig, I'm running over 4k on a 30a smaller alt and 34aH less in battery reserve. At IDLE, I drop to 12.9 at a min from 14.6ish volts full tilt after a full song.
Of course impedance rise plays a role, but that big of a role? Ehh..
What are your subs wired to, impedance wise? Check that voltage with a DMM.
What are your current grounds like?
I'm concerned.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
I'm concerned.
I agree.
Seeing battery rest, with that bank, with a 2k, and a damn decent alt, you have a problem....
Do you run at .25 or something?
you have more drop then me when I have stock alt,d925,D3100 on a 2200. even when I'm at idle.
You don't need a second run since you don't have enough alt to make use of it really. I'd check my batteries and look at another one
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Yeah I guess it could be the reserve. Or the alt. Idk. I got paperwork with the alt when i bought it secondhand, and it has a new voltage regulator. I've got two of these guys. http://www.osibatteries.com/p-1055-enersys-powersafe-sbs-c11-sealed-lead-acid-battery-120v-910ah.aspx They charge and rest like my front batt so they should be fine right ?
I'm running the 18 at 1 ohm before box rise, deck is an 80prs, gains set by dd1.
Alt - Singer 330A
